Keyfob Deadbolt
Intro: Keyfob Deadbolt
The key to my apartment never worked quite right because it is a copy of a copy of a copy. I am fairly certain that the dead bolt is original to the building and the property manager seems to have lost the original key years ago. As a result unlocking the door was always a pain. Changing the lock wasn't an option, but eliminating the need to use a key was.
Parts:
Arduino Uno
RF transmitter and receiver
Servo
2 Push Button Switches
Red LED
Green LED
Various Resistors
piezoelectric speaker
Perf Board
STEP 1: Mounting Parts
I used a couple of pieces of acrylic that I acquired in the dumpster of the plastic shop next to my place of work (they throw out alot of small pieces like this). Alternatively another material could be used if you don't have access to acrylic, but it is easy to work with and looks cool.
Using a piece of paper trace the mounting holes for your dead bolt and transfer them onto your acrylic sheet. Since most dead bolts are going to be slightly different I am not sharing the template I made out of a piece of paper (mainly because it isn't anything worth sharing).
Leave the paper covering on while working with the acrylic. The paper makes it easy to mark where to cut/drill as well as protects the material from scratches. Once all of your cuts are made and your holes are drilled you can start installing components such as LEDs and switches.
STEP 2: Servo
I used an old parallax servo I had in my parts bin. This small servo is more than strong enough to turn the deadbolt. In order to attach the servo to the lock shaft I used epoxy putty. Epoxy putty is very easy to use and is extremely versatile. The wire you see sticking out of the putty will be used as the arm for the limit switch.
At some point the wires to my servo had been cut so I had to open the case and solder on new ones. I took that opportunity to solder on a second wire to the 5v line and connected it to the limit switch arm.
STEP 3: Wiring
Screws were countersunk from the back of the acrylic. A wire was attached to each screw and then to a digital pin on the Arduino. When the wiper with the 5v wire touches the screw it pulls the digital pin high on the Arduino. Please see the schematic for further details.
STEP 4: Program
Disclaimer: I am not a programmer and therefore the below code may not be the most efficient. Feel free to improve the code for your own uses if you see any errors or problems. It works for me so I hope it works for you.
// turn CW to lock and CCW to unlock
//1700 CCW; 1500 Stop; 1300 CW
//written by Chris Rybitski
#include <Servo.h>
Servo deadbolt; // create servo
const int CWLimit = 6; // Limit Switch on 6 Unlock
const int CCWLimit = 7; // Limit Switch on 7 Lock
const int Redbtn = 12; //red push button
const int Blackbtn = 8; //black push button
const int GreenLED = 10; // Green LED
const int RedLED = 11; //Red LED
const int Ch1 = 5; //rf channel 1
const int Ch2 = 4; //rf channel 2
const int Buzz = 9; //buzzer
int Unlock = 0;
int Lock = 0;
int timer = 0;
boolean UnLcomplete = false;
boolean Lcomplete = false;
void setup()
Serial.begin(9600);
deadbolt.attach(3); // attaches the servo
pinMode(GreenLED, OUTPUT);
pinMode(RedLED, OUTPUT);
pinMode(Buzz,OUTPUT);
pinMode(CWLimit, INPUT);
pinMode(CCWLimit, INPUT);
pinMode(Redbtn, INPUT);
pinMode(Blackbtn, INPUT);
pinMode(Ch1, INPUT);
pinMode(Ch2, INPUT);
//set LED's and Buzzer to be off by default
digitalWrite(GreenLED, HIGH);
digitalWrite(RedLED, HIGH);
digitalWrite(Buzz, HIGH);
void loop()
if (digitalRead(Ch1) == HIGH || digitalRead(Redbtn) == LOW){ //If remote or button is pressed
if(UnLcomplete == false){ //dont run unlock if door is already unlocked
Serial.println("UnLock");
Unlock = 1;}}
if (digitalRead(Ch2) == HIGH || digitalRead(Blackbtn) == LOW){ //If remote or button is pressed
if(Lcomplete == false){ //dont run lock if door is already locked
Serial.println("Lock");
Lock = 1;}}
//---------------UNLOCK-------------------------
if (Unlock == 1){
timer = 0;
while (digitalRead(CWLimit) == LOW){
if (timer > 1500){
digitalWrite(Buzz, LOW);
delay(500);
else{
deadbolt.write(1700);
timer++;
delay(1);
deadbolt.write(1500); //servo stop
digitalWrite(RedLED, LOW);
UnLcomplete = true; //unlock complete
Lcomplete = false; //reset Lock boolean
delay(100);
Unlock = 0; //reset
//--------------LOCK----------------------------
if (Lock == 1){
timer = 0;
while (digitalRead(CCWLimit) == LOW){
if (timer > 1500){
delay(500);
else{
deadbolt.write(1300);
timer++;
delay(1);
digitalWrite(GreenLED, LOW);
Lcomplete = true; //lock complete
UnLcomplete = false; //reset Lock boolean
delay(100);
delay(50);
delay(100);
Lock = 0; //reset
#include <Servo.h>
int Unlock = 0;
int Lock = 0;
int timer = 0;
void setup()
Serial.begin(9600);
void loop()
Unlock = 1;}}
Lock = 1;}}
if (Unlock == 1){
timer = 0;
if (timer > 1500){
delay(500);
else{
timer++;
delay(1);
delay(100);
Unlock = 0; //reset
if (Lock == 1){
timer = 0;
if (timer > 1500){
delay(500);
else{
timer++;
delay(1);
delay(100);
delay(50);
delay(100);
Lock = 0; //reset
STEP 5: FInal Thoughts
Currently the unit is powered via the USB port using a cell phone charger. There are plans to wire a separate 5 volt supply that does not require the usb cable extending past the door. Although a key can still be used to unlock the door from the outside I am also planning on adding a battery back up in case of power failure.
49 Comments
Julian737 7 years ago
The link for the RF transmitter and receiver is broken... any chance you have the module specificaitons?
jaikesnake 7 years ago
could you reply with some websites where you got all the parts to make this including the program you used to code the key fob? I know this might be a bit of a nuisance but I'm fairly new to this so it would be really appreciated. :)
simplistik 11 years ago
rybitski 11 years ago
MarkAvenius 8 years ago
You made a cruise ship with an Arduino? That sounds awesome ;-)
daflippymaster 9 years ago
Is the servo directly attached to the deadbolt? If so, does this servo have any resistance to manually turning it (like when you use the key to open the door)?
I'm not very familiar with servos. Can you freely turn continuous rotation servos when they are off? I have a standard servo and it is resistant to turning when off.
ramgarden 9 years ago
Do you still work near that plastics place? Can we pay you for shipping to get us some from the trash? Or can we contact them directly?
jester04 9 years ago
If anyone is looking for cheap components and parts,go on aliexpress.com, shipping takes a while but it is worth it in the long run
rybitski 9 years ago
kevindiffily 9 years ago
Can you provide the specifics of the servo? I'm trying to size one in terms of power and torque for my deadbolt knob.
Ero4820 9 years ago
Hello, Wich program you use for this project ? :)
nelo_007 11 years ago
chillas 11 years ago
Quick question - what happens if someone does unlock with a key? Does the system still know what state it is in, locked or unlocked?
jcksparr0w 11 years ago
waterski4life1 11 years ago
