KillerK's MAGNUM
Intro: KillerK's MAGNUM
Since KillerK would not post his MAGNUM I decided to take matters into my own hands. Plus, all these kids who don't have enough skill to build it from the pictures he's posted were begging me to. So here it is, KillerK's MAGNUM.
Enjoy.
Enjoy.
STEP 1: The Barrel.
1.)Build these.
2.)Add these.
3.)Connect them.
4.)Begin assembling the barrel. (If you are confused about which sections you connect, refer to picture 5.)
5.)The product of step four.
6.)Connect to section from pictures 4 & 5. (If you are confused refer to picture 7.)
7.)Product of 6.
8.)What you should have.
9.)Done.
2.)Add these.
3.)Connect them.
7.)Product of 6.
9.)Done.
STEP 2: Barrel Connectors.
1.) Build these.
2.)Done.
2.)Done.
STEP 3: Handle & Trigger Guard
1.)Build this.
2.)Build this.
3 & 4.)Inset 1 into 2.
5.)Product of 3 & 4.
6.)What you should have so far.
7.)Add these.
8.)Add the rest of the greens.
9.)Build these.
10.)Add them to the Handle.
11.)Done
2.)Build this.
7.)Add these.
9.)Build these.
11.)Done
STEP 4: Ram & Trigger
1.)Take a normal green connector piece and cut this part off with a hammer and a screwdriver like this.
2.)Finished Product.
3.)Connect it like this.
4.)Done.
4.)Done.
STEP 5: Putting the Rear of the Barrel Together.
1.)Put these on these things.
2.)Connect them to the end of the upperportion of the barrel like this.
3.)What you should have so far.
4.)Add the bottom portion of the barrel to the piece recently added.
5.)What you should have so far.
7.)Add these to strengthen the gun.
8.)Done
8.)Done
STEP 6: Putting the Front End of the Barrel Together.
1.)Connect these two things like this.
2.)add it to the front like this.
3.)Add these to the front.
4.)Done
4.)Done
STEP 7: Inserting the Ram.
1.)This is what you are inserting.
2.)Create a bow in the middle of the barrel like so.
3.)This is the easiest way to insert it.
4.)This is how it should look if you did it properly.
5.)Done.
5.)Done.
STEP 8: Add the Actual Barrel.
1.)You slide this piece into here.
2 & 3.)This is what it should look like if you did it porperly.
4.)Done
4.)Done
STEP 9: Adding the Handle & Trigger.
1.)Take this piece...
2.)And connect it here...
3.)Like this.
4.)Connect the Handle.
5.)Add these little guys here.
6.)Done.
3.)Like this.
6.)Done.
STEP 10: Adding the Rubberbands.
1.)Put one like this.
2.)Put the other like this.
3.)Done.
3.)Done.
STEP 11: Mods
1 & 2.)These keep the "safe" out of the way.
3.)This really isn't a mod, but these are my some possibilities of KillerK's "MAGNUM Round." If you try to just shoot a normal rod, it will either fall inside the gun and jam it and possibly break your ram, or will just simply fall out. This is my solution.
111 Comments
ttran-1 11 years ago
knexcannon 13 years ago
misectet 14 years ago
KnexFreek 14 years ago
Hiyadudez 14 years ago
LOOK at the really close-up picture of the turret on it, whaddayathinkofthat?!?
Tominator 16 years ago
An Villain 14 years ago
knexsuperbuilderfreak 15 years ago
Master_Zane 15 years ago
mikmanmaster 14 years ago
gunmaster222 15 years ago
timmit99 15 years ago
J3R3mYAnD3R$oN 15 years ago
Metal4God 16 years ago
quincy85wrestler 16 years ago
