Kindle Fire Sporran
5,122
49
8
Introduction: Kindle Fire Sporran
Kindle sporran?  Isn't that something you get at the drugstore that comes in a tube?
Actually, a sporran is like a little packet that can be threaded onto a belt.  It's typically worn by men who wear kilts because kilts don't have pockets.  This is a variation on that idea which will allow me to carry my Kindle around hands free.
I've been thinking about making this ever since I discovered coursera.  I enjoy listening to the lectures while I'm doing other things, but without this I would otherwise have to devote an extra hand to holding the tablet.
Step 1: Materials
small amount of fabric
sewing machine
scissors
chalk
two 5 inch lengths of thin wire
iron
Step 2: Trace
Using the chalk, trace around the kindle as indicated.
I'm using a 1/4" seam allowance - which is about the diameter of my chalk line.
Trace around it once, then flip it over and trace again as shown - like a book cover.
Rough in an 1-1/4" margin around one side to be the window opening.
Trace out an extra little square to be the pocket to keep the headphones in.
Cut two additional rectangles of fabric approximately 2 inches wide by 6 inches long - to be the belt straps.
Step 3: Cut the Window Out
Fold the main piece in half as shown and sketch in the seams for the window as shown.
Cut out the center rectangle and cut the darts in the window seam allowances.
Step 4: Flatten the Window Edges
Fold down the window edges and iron them flat
Step 5: Top Stitch Window Frame
Step 6: Create an Envelope
Sew around two sides - leaving an opening for the kindle to slide in.
If you need to, hem the open edge.
Invert it and see if the Kindle will fit.
My fabric wasn't stiff enough on it's own to hold it's shape, so I'm going to insert a bit of wire into the long window edges.
Step 7: Stiffen Up Soggy Edge
This part is a bit iffy, as you don't want to scratch the screen of your Kindle with the wire.  So if you don't mind the soggy window edge, you can just leave it - or if you have a better material to stiffen it with, that  might be a good suggestion.
neo71665 suggests bamboo skewers - wish I'd thought of that!
Step 8: Prepare the Pocket
Iron down the edges of the pocket.
Top stitch it.
Hem the opening edge if necessary.
Step 9: Position and Attach the Pocket
With the Kindle inside, position the pocket and trace around it with chalk.
Remove the Kindle, invert it and sew the pocket into place.
Step 10: Create the Straps
Fold the strap material in half.
Sew along the longest length
Invert it
Iron it flat
Top stitch it.
Step 11: Attach the Straps
With the Kindle inside, position the straps and mark the edges with chalk.
Remove the Kindle and sew the straps in place.
Step 12: Yay Good!
Thread it onto your belt and you are good to go.
Convenient?   Check!
Nerdy?             Check!
Don't roam too far away from the internet signal!
Be the First to Share
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    • Hand Tools Only Challenge
    8 Discussions
    clupoli
    clupoli
    5 years ago
    Also... Corset boning will "spring back" unlike a wire hanger.
    clupoli
    clupoli
    5 years ago
    Another useful way to stiffen the front would be to use good iron-on interfacing or use corset boning the same basic way you would the wire hanger or skewer. A skewer might break too easily.
    DragonDon
    DragonDon
    7 years ago on Introduction
    I was wondering how this would be useful then I saw the lat pic....oooh....while you are working....definitely useful if you are no where near a power outlet to consult digital plans. Nice.
    bob3030
    bob3030
    7 years ago
    Great instructable. I always like seeing projects where sewing is used. I think those early guys/gals with a needle (awl) and thread (sinew) were some of the first "makers ". Thanks for posting.
    foobear
    foobear
    Yes a sewing machine is an incredibly versatile tool - you can accomplish an awful lot with just sewing stuff.
    neo71665
    neo71665
    7 years ago
    Bamboo skewers might be easy to get and not scratch the screen.
