Kite Skateboard
Intro: Kite Skateboard
I decided to share this project with you even though I didnt take any photos of its first steps ,Yet I am posting the photos of 90% of this project hoping this would be helpfull .
I used 3 sheet of ply wood to make the Skate body and pressed it with weight to get it into Arc shape (as per first few photos).
I have also used a tin sheet metal from an old cabinet drawer to enforce the Kiteboard top and bottom .
Then I ran a 2" leafspring sheet on the bottom portion of the board tip to tip to work as a shock absorber.
18 Comments
stumitch 9 years ago
Wow! what a great job! I build longboards for a side job and it really is easy to build boards using a vacuum bag and lots of maple layers. Maybe even eliminate the need for steel reinforcing if you do it that way. My one add might be if you are needing a different turn radius you can go up to a 44deg kick (upturn) for the truck mounts. cool project!
mbourhan 9 years ago
Hey Stumitch
Thanks,
GDADZGSONS 11 years ago
mbourhan 11 years ago
- in order to get the tips in the opposite angle I jammed the tips in a vice and pulled the board from the medel using a strap ,I use to spray the wood with water during molding it into the final shape and leave for days before i repeat the action for the other sides tip.
when finaly had it the way it looks now ,drilled the holes for all the wheel assy and the foot straps .the tires cane from a hand trolly .
Please let me know if you need any more details also you can google " mountain boards" or "kite skates " for different shapes and sizes of the same also you cane got to : www.seabreeze.com.au for a varity of DIY wind power projects ,
PS.
I have done some other related projects but never had the chance to post ,the photos were random but available
ElvenChild 12 years ago
mbourhan 12 years ago
you are right ,I also see it as such "a DirtBoard"
Tray 12 years ago
Close enough
I got them from an old Forklift engine ,but I had to expand them a bit pass the elastic point to gain more blank space in between the sprig rings, I did it because it was too hard to steer back into straight position ( I weigh 95 kg ) and these springs stores enough energy to do the job , they worked like a charm
Chip13 10 years ago
What are this wheels from?
mbourhan 10 years ago
hey,
I found them in the local market, they use them for two wheels type hand trolly
thanks
what template do exactly mean , I realy want to help.
Thanks
freeza36 12 years ago
Kiteman 12 years ago
thanks for viewing my project,hope you find it good
As per step-by-step instructable,Well, It was planned this way,but for some reason I spent more than 7 hrs and 6 attempts to Upload the photos and every time I upload a good number of them something goes wrong with the network and send me back to the blank upload page ,
So I went on and published what I found saved in my library with some or no comments at all
Anyhow I am willing to answer any question .
