Kitty Litter Box
Intro: Kitty Litter Box
I was tired of cleaning spilled and tracked litter around the cat litter box. I also needed one that kept the dogs out. I went to the local pet store to find a better solution. The one I liked was about 30 dollars. I figured I could make one for much less. Hope you like it. The cats sure do!
For this project, you will need:
1. A Plastic Storage tote (mine was about 18 gallons or so.
2. A piece of indoor/outdoor carpet, to fit the top of the lid. (you could use a doormat or even a automobile floor mat)
3. Scissors or a utility knife.
4. A marker
5. Liner (I used a lawn and leaf bag)
6. Kitty litter
7. A cat named Biscuit or Chau or by any other name. (If you don't already have one)
4. A marker
6. Kitty litter
STEP 1: Get a Plastic Storage Tote
I found an 18 gallon tote with lid the latches for about 6 bucks.
STEP 2: Draw the Entry Way on the Lid.
I used a bowl to draw about an 8 inch circle for the entry way
STEP 3: Cut Out the Entry Way
I used a utility knife blade because I could not find my utility knife. (It would be much easier if the blade is in the knife). Hopefully, you can find yours.
STEP 4: Make Pattern for Carpet Top
Use a large piece of paper to trace and make a pattern to fit on top of the lid. I used a piece of drawing paper from big roll of paper my Grand Kids use. But a piece of butcher paper or wrapping paper would do the trick as well. Make it so that it fits inside the raised edges of the lid.
STEP 5: Cut the Carpet Top to Fit.
I was able to cut the carpet top with scissors. You can tape the pattern to the carpet or just draw around it with a marker.
STEP 6: Cut the Circled Entry Way Out of the Carpet
Again I used scissors to do this, but a utility knife would probably work better.
STEP 7: Liner and Litter.
I used a Lawn and Leaf bag as a liner. It fit really tight around the container. Then I added some litter.
STEP 8: Complete!
Put the lid on and latch it. Place the carpet on top. You may want to use double sided carpet tape or even Velcro. I did not want to glue it because I want to be able to remove it and wash it when needed with the water hose. I like this design with the entry hole on one end. That way the cats have plenty of room to jump on top.
5 Comments
robi27 10 years ago
Definitely making this! My kitten is a terrible litter maniac and there's more on the floor than in her box.
uffdabaybee 9 years ago
Hello! I made 2 of these, the first I made was with carpet on top (duck tape on--) problem was the duck tape lasted holding them onto the box than the carpeting stayed clean) so with the 2nd one I used self adhesive stair treads!! (bought at menards) and that has been perfect... love it and have put the stair tread on the first litter box.
Sars Jones 10 years ago
I loved this. Out of all the top-entry litter box tutorials this helped me best realize my vision. I didn't mess with large bags or attachments but instead had a small size litter box that fit perfectly into the large bin. The velcro tip was key! I found a dish mat that was on sale for $8 and made out of foam so it was really easy to cut and not a lot of fraying. Thanks again!
georion 11 years ago
rimar2000 11 years ago
