Knew Sniper With New Trigger System
Introduction: Knew Sniper With New Trigger System
Step 1: Scope, Bi-Pod, Magazine
1 - the scope when finished
2 - make these
3 - and these
4 - and some more
5 - one end of the scope, make sure you dont join every second red rod to one end
6 - the other end of the scope, dont join every second grey rod to one end
7 - add this
8 - add the orange connectors (pic 2) and these (pic 4)
9 - this part joins to the gun (detachable)
10 - scopes finished
11 - make this
12 - make this
13 - make this
14 - put pics 12 and 13 together
15 - add pic 11, and finished
16 - for instructions got to https://www.instructables.com/id/SZ7T0J0FCUJWCTI/
17 - make it like this
18 - make it like this
19 - same agian
20 - add pic 15
21 - finished bi-pod
22 - magazine
23 - ammo pusher
24 - your ammo
Step 2: Barrel
1 - front sight
2 - make this
3 - top rail pt 1
4 - top rail pt 2
5 - top rail pt 1 - 2
6 - make two of each and add blue rods to one of them
7 - connect them
8 - make bottom rail
9 - connect them
10 - add bottom rail to side with blue rods
11 - add the other side
12 - add top rail
13 - top rail pt 3
14 - make this
15 - and this
16 - make two of these one with out blue rods
17 - add these
18 - add the other side and the top rail pt 3
19 - connect like so
20 - add pic 2 like this
21 - what it should look like
22 - almost finished
23 - just add the front sight
Step 3: Stock, Trigger System
1 - make two of these one without the blue rods
2 - make 3 of these
3 - add them and the other side
4 - make 2 of this
5 - make this
6 - what it should look like
7 - trigger
8 - UPDATED: make this (sort of like a bolt)
9 - UPDATED: the blue rod should look like this
10 - add this
11 - make top rail pt 4
12 - make this
13 - this
14 - and this
15 - make 3 of these
16 - make 2 of these
17 - make this just once
18 - UPDATED: make it so it looks like this so far
19 - close up
20 - add parts of the rail pt 4
21 - add the trigger parts
22 - UPDATED: ram pt 1
23 - UPDATED: ram pt 2
24 - ram pt 3
25 - add the ram
26 - almost done
27 - add these little things
28 - add the stock and your almost done
29 - UPDATED: connect the barrel and your finished
30 - UPDATED: make these for the rubber bands
Step 4: Scope, Bi-pod Placements
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • For the Home Contest
    51 Comments
    Soopah Steve
    Soopah Steve
    13 years ago on Introduction
    Nice gun. 4.5* You might want to change the title though, the trigger is nothing really new. Its basically a block trigger that goes up and down. With a truegger attached,
    Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    coreyt
    coreyt
    13 years ago on Step 3
    this trigger is othing new id change it
    coreyt
    coreyt
    Reply 13 years ago on Step 3
    id change thething that says new trigger system
    DJ Radio
    DJ Radio
    Pretty cool, but this gun needs a handle.
    Whaleman
    Whaleman
    Reply 13 years ago on Introduction
    It has a handle. It's right behind the trigger. You just don't wrap your hand all the way around it.
    Whaleman
    Whaleman
    Who are you to decide it's not good enough? It's a handle. The original gun was just a straight stick with a miniature cannon on the end. How comfortable do you think that was? This handle will work. Make your own if you want.
    Whaleman
    Whaleman
    No problem. Keep up with the innovative work. If you can start capitalising your words, you can come over to http://www.knexinnovation.net . Only reason to start capitalizing is because we (KI) have a rule about no text speak or needlessly poor grammar.
    Whaleman
    Whaleman
    But not the ever present beginning of EVERY SENTENCE. OHAY, looks like you have that problem, too.
    DJ Radio
    DJ Radio
    I dont really care, it aint needed on ibles.
    Whaleman
    Whaleman
    Then why did you capitalise the beginning of your sentence? Before you reply saying that you capitalized it because it was 'I' and not because it was the beginning of the sentence, I don't care. All I want to do is point out your hypocrisy of capitalizing some stuff and not others. Also, I want you to watch the video in my above post.
