Introduction: Knex Ball Machine Lift: Triple Moving Arm Lift
Hey everyone,
Here are instructions for the Knex Triple Arm Lift (a knex ball machine lift).
The lift is quite easy to make and rotates very smooth when the instructions are carefully followed. As you can see by the title, the lift makes 3 separate movements when only 1 (6V) motor with 2 dubble A batteries is required.
The lift can also handle multiple knex balls at one time thanks to a little ball dispenser that is connected to the same motor that rotates the lift.
Make sure to check out Step nr 1 to see if you have all the special pieces you need to make this lift, (like Micro Knex pieces, the big green gear, etc...).
If there are any complains, questions or problems about the lift, please tell me in the comments below.
Thanks for watching, building,
Thibault Art.
Step 1: Special Pieces You Need:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10: Very Important Step:
Make sure that all 3 oranje connectors are going upwards. Once you're sure, you can take the 3 connectors of.
Step 11:
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Step 17:
Step 18: Another Important Step:
Make sure that you push the little button of the motor to the right.
Step 19: Third Important Step:
When the 2 rotating imputs are perfectly horizontal, make sure that the little ball dispenser is in the same position as shown on the picture.
19 Comments
Question 1 year ago
Made this - best one so far - but it doesn’t work for me.
Only one ball gets picked every so often, the rest miss.
It appears to be not synchronised for some reason.
have I missed something?
Answer 1 year ago
Ok - yellow gear has 82 teeth - green gear has 84 - hence not synchronised.
I replace the green gear with a yellow one and now it works.
6 years ago
That is a really cool ball machine lift! May I ask where you got the special green gear from? I can't find where to get one :/
Reply 6 years ago
Thanks for your comment! You can buy one of those green gears on the "K'NEX User group" site. here's a link if you're interested:
http://www.knexusergroup.org.uk/acatalog/knex-part...
I would recommend that you hurry though. It's a knex piece that hase been discontinued a while ago and they are almost sold out.
Reply 6 years ago
Unfortunately, the gear isn't available to the USA or Canada... Do you know of any other way to use maybe a large yellow gear?
Reply 6 years ago
Oh, well I think there is a way to make this lift work with a Large yellow gear. And if you have a bit of experience with Knex, it shouldn't be to hard.
I can send you a picture tomorrow with (maybe) a solution to this problem if you would like?
6 years ago
I love the things people make out of K'NEX, especially ball machines and lifts! Excellent work, thanks for sharing.
Reply 6 years ago
No problem, I'm happy you like it :).
6 years ago
It's not an efficient lift, but Who Cares! :D
This is the most beautiful one I have seen so far. Mesmerizing movements and great instructions!
Keep it up!
Reply 6 years ago
True, it is indeed not the most efficient lift I've ever made XD.
6 years ago
I like all of these ball machines. You are very talented in making ball machines.
Reply 6 years ago
6 years ago
Very nice K'NEX ball machine lift, Thibault Art! Your work always impresses me. :)
Reply 6 years ago
Thanks a lot :)
Reply 6 years ago
You're welcome! :)
6 years ago
Great work dude!
Keep it up! (Still waiting for the other 3 lifts)
-OfficialKNEXGUY
Reply 6 years ago
Thanks! They are all coming very soon. I'm just not going to make instructions for the 4th lift you see in the video. The 4th lift uses Cyber Knex, which makes it very hard to explain because every teeth of every gear needs to be perfectly placed. But the first and third lift will have instructions :).
6 years ago
And that is best i have seen, more like this please nice work.
Reply 6 years ago
Thanks! The next one will be posted in a few hours.
