Introduction: Knex Grenade
Step 1: Gather the Parts
This may be annoying. It may fall apart ALOT! It just takes practice. I had trouble! I hope you enjoy!
Parts list:
-I yellow rod
-I dark grey oval looking thing
-I orange thing
-8 Yellow connectors
-8 Green Connectors
-2 white connectors
-18 light grey connectors (You can substitute for this piece)
-8 red connectors
Step 2: Make the Pin
This will activate it if pulled
Step 3: Start the Base
Start the base
Step 4: Make the Center Layer
Use the yellow connectors
Step 5: Insert the Pin Into the Bottom
The title says
Step 6: Add the "Explosion"
Dump all the light grey connectors into the body
Step 7: Make the Top Layer
Use the 8 red connectors and the 1 remaining white connector
Step 8: Put All the Layers Together
Now push the top layer onto the middle layer
Step 9: Secure the Pin
Now use the dark grey piece to secure the top of the pin
Step 10: Your Done! Now to Set It Off
Good job! Now remove the top grey piece and then remove the pin. Now just drop for an epic explosion! Have fun!
