Knex Hidden Blade
Intro: Knex Hidden Blade
This is an Assasins creed hidden blade that is triggered by moving your hand in an upwards motion. You can use it to pretend to be Ezio etc.
STEP 1: You Will Need:
You will need:
Connectors:
Red / quarter - 7
Half moon - 9
Grey / two slot - 3
Tan clip - 1
Orange - 1
y clip - 1
Rods:
white - 11
grey - 1
blue - 1
green 1
other:
tape
string
Connectors:
Red / quarter - 7
Half moon - 9
Grey / two slot - 3
Tan clip - 1
Orange - 1
y clip - 1
Rods:
white - 11
grey - 1
blue - 1
green 1
other:
tape
string
STEP 2: Build
Look at the picture. It is simple enough to build from this pic.
STEP 3: Put It Together
1.Put the trigger on the end of the body
2.put the y clip on the end
3.Put the grey rod in the body
STEP 4: Other Stuff
1. Put tape on the hammer
2. Put an elastic band on it
3.Push down the hammer until the trigger stops it from coming out
4.Put on elastic bands to wear it
5.Thread string through the two grey connectors
6.Put end of string on your finger. You may need to adjust it to make sure that it is very tight
7.Pull on string with finger to use
STEP 5: You're Done!
You are done!!!
18 Comments
dustydino 10 years ago
i changed blue to white also
knexbug 10 years ago
joshqua 11 years ago
patriots8888 12 years ago
TigerNod 12 years ago
the master 2 12 years ago
H1T4TCH1 13 years ago
Thanks ;-)
fairyqueen2010 13 years ago
greenguy421 13 years ago
keir111113 13 years ago
keir111114 13 years ago
Vynash 13 years ago
It's not that bad, but you could work on it a bit :-)
the master 2 13 years ago
Vynash 13 years ago
~KGB~ 13 years ago
~KGB~ 13 years ago
