Knex Hole Puncher
Intro: Knex Hole Puncher
This is a collaboration project between Me and Hiyadudez.
P.S. If you subscribe to me, subscribe to Hiyadudez too. :-)
As you may have already noticed, it is a hole puncher.
This cool little gadget is an essential on your desk/workplace. It is a 2-holed puncher that is activated by pushing your hand on the top, which makes 2 perfect holes in the paper. It does this with two slightly sharpened rods. Also, there's a little tray in the back which can hold stuff like business cards, pencils, rulers, scissors, or even lollipops.
Also, this was featured on Geekosystem. :-D
EDIT: This reached 4.50* And yes, I know it's 5* now, but it got to 4.5 under the old rating system.
Here's a video of the hole puncher in action:
We hope you like it!
STEP 1: Gather the Pieces
Here's all of the pieces you'll need to build the 2-hole puncher.
Rods: 163
If you have all of these pieces, then let's get crackin'!
Rods: 163
- green- 105
- white- 39
- blue- 8
- yellow- 6
- red- 5
- dark gray- 28
- light gray- 0!
- red- 8
- green- 4
- yellow- 17
- white- 10
- orange- 12
- blue- 7
- purple- 32
- Hinges- 2 (4 pieces)
- Small domes/wheels- 2
- Blue spacer- 61
- Silver spacer- 18
- Y-clips- 23
- 1 thick rubber band
- Tan clip- 4
- Metallic blue clip- 1
STEP 2: The Base, Part 1
Now that you have your pieces together, you're ready to build. To start off, let's build Part 1 of the base. Make sure to place all of the pieces exactly like they are in the pictures. Also, pay attention to the image notes.
STEP 3: The Base, Part 2
This step is super easy. Just build what is in the picture.
STEP 4: Combining Parts 1 and 2 of the Base
Now that you've built Parts 1 and 2, put them together. There should be a thin space in between the top and bottom parts. This is where the paper will slide into.
STEP 5: The Back
Now it's time to build the back of the hole puncher. You'll need your thick rubber band in this step. Put it on exactly like it is in the pictures.
STEP 6: Combining the Back to the Base
Let's combine the back to the base. Again, make sure the rubber band in your model is placed exactly like the one in the pictures.
STEP 7: The Puncher
Now that you're done with the base, you're going to build the puncher (yes, I can't think of a better name for it XD). It consists of parts A and B. Get your pencil sharpener or sandpaper out, because you'll need it to sharpen the two white rods. Refer to the 7th picture to see how much you should sharpen it. After you build them, you'll combine the two Parts.
STEP 8: Combining the Puncher to the Base
Now you'll combine the base and the puncher. Make sure everything is lined up. Don't put the rubber band onto the hinges yet. It may be difficult to attach some parts on the inside, but you'll just have to get your fingers in there and snap 'em in. And make sure the two sharpened rods are in the connector's holes.
STEP 9: The Bottom, Part 1
Now you'll build the bottom, part 1. It's very easy.
STEP 10: Combining Part 1 of the Bottom to the Model
Now that you've built part 1 of the bottom, attach it to the model. The three y-clips will go into the slot on the blue connector (picture 3 shows this in detail).
STEP 11: The Bottom, Part 2
Build Part 2 of the bottom. Pretty easy.
STEP 12: Combining Part 2 of the Bottom to the Model
Combine Part 2 of the Bottom to the rest of the model. The 5 Y-clips are the only things that connect to anything. It rests on top of Part 1 of the Bottom.
STEP 13: The Holding Tray
This is the tray that will hold stuff. This is an easy step.
STEP 14: Combining the Tray to the Model
Now you'll attach the tray to the back of the model. And you'll finally get to put the rubber band onto the hinges.
STEP 15: The Front
This little section will make the front of your hole puncher look and work much better.
STEP 16: Combining the Front to the Model
Put the front on the model in front of the puncher.
STEP 17: The Orange Things
I can't think of a better name for this, so it's called: The Orange Things. There's also the black wheels attached to white rods. This stuff is just there for looks and comfort.
STEP 18: Combining the Orange Things to the Model
You're almost done! Just attach the Orange Things and wheels to the model.
STEP 19: Finished!!!
Congrats, you are now done with our 2-hole puncher!!!! Now that you're done, you'll want to use it. So, get some paper and punch the holes in it (pictures below). It doesn't really matter what type of paper you use, but don't use something that's too thick (like cardboard). Of course, you can sharpen the rods more to make it punch through cardboard or more sheets of paper. :-)
Have fun punching holes in paper!
Don't forget to subscribe to me and Hiyadudez!!
321 Comments
zzyzx116 1 year ago
Knexified 3 years ago
Shadowman39 3 years ago
dynamite_kid 6 years ago
thats very handy
and its excellent
Shadowman39 6 years ago
Thanks!
Borisv9 7 years ago
lawl, thats great
Shadowman39 7 years ago
Thanks!
The Knex Inventor 7 years ago
Will this work without sharpened rods?
Most likely yes, it just might not punch holes as well as sharpened rods.
Neat! I will try that.
Homestar 14 years ago
Shadowman39 14 years ago
www139 10 years ago
Shadowman39 10 years ago
Sorunome 10 years ago
www139 10 years ago
I heard that k'nextream is too!!
