Introduction: K'nex Landmine/ Grenade
Step 1: Firing Mech
This is the Firing mechanism that makes the grenade explode. since the bullet doesnt go all the way in the barrel, it smacks it and makes the grenade blow up. Make sure to tape the firing pin. adjust the rubber bands so that if you pull it back, put it at a 45 degree angle, load in a white rod, and shoot it, it should go 15 to 20 feet. here i used 3 thin rubber bands.
Step 2: Stand
this is the stand that holds everything up. make sure to put something small but semi-heavy on the leg opposite of the trip wire. (in my case, a rock band drum pedal.)
Step 3: Grenade
this is easy, just build it. you can use any knex grenade that fits together loosely like this just ad a white rod
Step 4: Tie to a Doorstop or Some Nail Sticking Out of a Wall or Something
I suggest tying it to a door stop with string and when someone opens the door it goes off. its less noticeable if you put it there and gets you by surprise.
to load it, pull it down the firing pin and load in the grenade. when the trip wire is pulled, it goes off and scatters shrapnel everywhere.
47 Comments
11 years ago on Introduction
This worked great for the grenade I used, it exploded at chest height and actually hurt a bit. The only thing is that the trigger where the string is attached should be lengthened to get more leverage. And on ceramic I needed a weight to stop to door from pulling it away. Great booby trap.
11 years ago on Step 3
I have a better grenade for this. Instead of spreading over the floor, the fragmentation shoots up and around. I will see if I can get a picture. I have also modded a little bit to it to make it more stable. I also made it so that when you tug on the wire, a pin removes itself so the wire doesn't trip anyone. Thank you so much for the basic design. Very good for pranks
Reply 11 years ago on Step 3
Very cool. Yeah this design is VERY basic, so improvements are definitely needed. Thanks for building
12 years ago on Introduction
This is the so cool!
13 years ago on Step 1
Can i Sharpen Or will It Mess IT up
Reply 12 years ago on Step 1
yah good idea
13 years ago on Introduction
you have rockband!
Reply 13 years ago on Introduction
neeeeeveeerrrr...
allllllllwwwwwwaaaaayyyyyyssssss!
lol! i have gh world tour i used that instead.
that dont break it proves (kind of) that gh is betta than rockband cos rockband is a cheap, crappy immitation. thanks for listening.
Reply 12 years ago on Introduction
rockband sucks. medium feels like expert. the thing is completly stupid. i use my rockband drums on Guitar Hero 5
gd on u
mhm, now the pedal is broken in 2 places i have it held together with a ruler and tape
lol mine is broke right in the middle
5*s
awesome! 5 starz :-)
thankz
u can also just put a white rod in and lay it down on the ground and aim it at the door...
13 years ago on Step 4
if you stick the point of a red connector in the shaft it will fire the way it is pointed!!!
