Knex M47 Full Stock Shotgun/Rifle (with Actual Pump Action!!)
Intro: Knex M47 Full Stock Shotgun/Rifle (with Actual Pump Action!!)
This is a great knex gun that has an actual pump!!!
It is also now auto reloadable!!!!!!!
This gun has that great shotgun feel. Also it is a block trigger attached to a real trigger with a string. I did that because block triggers can handle the most tension. Also this way you can have a pump action shotgun that auto-reloads. It is not very complicated so anyone can build it, even begginers.
Stats:
Pump Action
Pretty Big mag
Shoots blues
shoots at least 50 ft.(with only 2 bands)
Don't Forget To Rate!!!
Here is my other video on knex guns
Stats:
Pump Action
Pretty Big mag
Shoots blues
STEP 1: The Barrel, the Trigger, and the Magazine
Look at the pictures to make the barrel.
I would advise putting a rubber band now on the trigger because it will be difficult to do that latter on.
You will need decapitated grays on this.
STEP 2: The Pump
Look at the pictures and build the pump.
STEP 3: The Handle
Look at the pictures and build the handle.
This is one of the most sturdiest handles built.
STEP 4: The Body/Frame of the Gun
This is the body/frame of the gun. i have the original body and the updated v2.0 body. just build the originall body then fix it up from the improvements from v2.0.
STEP 5: Connecting the Parts
1. Connect the firing pin and the pump to the barrel.
2. Connect the barrel to the body/frame.
3. Connect the handle to the body/frame.
4. Attach the opptional ammo clip (wont be auto-reloadable)
STEP 6: The True Trigger (optional)
This is an actual trigger with string attached to a block trigger.
Make sure that the string pulls the block trigger opposite the rubber bands!
STEP 7: The 3 Different Versions of the Shotgun
Here are all three versions of this shotgun.
As you can see the gun is a pump action semi automatic gun now.
STEP 8: Finished!!!
U are finished!!!
Now go shoot your younger sibling.
Just joking!!!
Just joking!!!
225 Comments
Creater0479 3 years ago
kaleb12345 13 years ago
The Jamalam 13 years ago
knexmaster1 13 years ago
dansdoc 13 years ago
Raikou-san 14 years ago
the dawg 14 years ago
now i have realised the error of my ways, this is acutally pretty crap but 5*'s just because i have "fond" memories of it xP
WULLYBOY1638 14 years ago
Andrew5909 14 years ago
ILIKEPIE333 14 years ago
KnexFreek 14 years ago
poolio 15 years ago
Jimpiedepimpie 14 years ago
poptart432 14 years ago
metroidfan123 14 years ago
sdds 15 years ago
J4mm3r5 15 years ago
brapbrapbrap 15 years ago
