Introduction: K'nex Mauser C96 Replica Instructions
So here as promised are the instructions for my Mauser C96
I made a new trigger gaurd it is somewhat round -> as pointed out by Dr. Richtofen (thanks.)
Okay before you start building read the following stuff.
- This gun requires at least one Broken piece (orange connector with one tab missing) without this piece the gun won't fire.
- Also two broken white rods are recommend, if you really dont want to break your white rods you'll have to make the outer panels somewhat different.
- The other five broken rods are just for looks, and since I had them I used them.
I didn't post the stock because it kinda sucked if I make a new one i'll add it in this instructable.
Well here are some pros and cons.
Pros
- Looks good.
- (Almost) no rods sticking out of the gun.
- Comfy broomhandle in the right angle.
- Long pin-pull
Cons
- Barrel/body connection is somewhat floppy nothing real big.
- Small mag (can be compensated with the mag extention.
- Shoots green rods.
- Not that great of a range
Step 1: Outer Panels.
Simple as that.
just make it twice.
Step 2: Inner Panels.
Also simple also make two here.
Step 3: Internals
Quite easy just follow the pictures + notes.
After you are done add the other panel from the previous step (forgot a pic.)
Step 4:
Step 5:
Well we'll put it together now (if you haven't already)
the pics are a little messy
Step 6: Extras
Almost done just the ramrod, mag push and the mag extention.
