Knex Miter Saw V 2
Intro: Knex Miter Saw V 2
Hello everyone!
Here is the new version of my miter saw. The meganism is updated which makes sure the blade guard goes up and down faster wile moving the saw part. After I saw 39 shadowman's miter saw i was like: I can build such a thing to and tada here it is. I really hope you guys like it and have fun with it after building.
Here is a video of it
Here is Shadowman's miter saw
edit: it reached 4.5 stars thanks for everyone who voted
STEP 1: The Parts List
Here are the parts you need to build the saw
Rods
Green- 113
White- 93
Blue- 193
Yellow- 69
Red- 12
Bendi yellow- 2
Bendi grey- 4
Total Rods: 486
Connectors
Dark grey- 12
Light grey- 2
Red- 36
Green- 3
Yellow- 45
White- 51
Orange- 43
Purple- 122
Blue- 52
Total connectors: 366
Others
Blue spacer- 43
Silver spacer- 24
Blue gear- 2
Red gear- 7
K'nex motor- 1
Mettalic blue clip- 2
Micro knex chain links- 49 ( can also be normal knex chain links)
Triangle panels- 2
Tan clips- 9
Rubber band- 2
String- 2
Total others: 141
Total: 995
If you have these parts, let's get building!!!
Rods
Green- 113
White- 93
Blue- 193
Yellow- 69
Red- 12
Bendi yellow- 2
Bendi grey- 4
Total Rods: 486
Connectors
Dark grey- 12
Light grey- 2
Red- 36
Green- 3
Yellow- 45
White- 51
Orange- 43
Purple- 122
Blue- 52
Others
Blue spacer- 43
Silver spacer- 24
Blue gear- 2
Red gear- 7
K'nex motor- 1
Triangle panels- 2
Tan clips- 9
Rubber band- 2
String- 2
Total others: 141
Total: 995
STEP 2: The Saw Base
This is the base on which the saw will rest. It costst a lot of blue rods but just get started and then the first step is done
STEP 3: The Meganism
This is the most complicated part of the saw but it isn't a lot of work so let's get building
STEP 4: The Base Top
This is the most easiest step in the instructable so just look carefully at the pictures and the base is done !!!!!
STEP 5: The Plating
This part of the innstructable isn't necesarry but it just makes the saw looks nicer
STEP 6: The Saw, Part 1
This is the first part of the which also has the motor
STEP 7: The Saw, Part 2
This is the upper part of the saw. This is also the part in wich the blade and the blade guard will be.
STEP 8: Attaching the Saw to the Base
Just attach the saw to the base
STEP 9: The Rubber Bands and the String
Just put the rubber band where it says to but READ THIS: THE STRING MUST BE AT HIS MOST THIGHT WHEN THE SAW IS UP
STEP 10: You Are Finished!!!
Congragulations, you finished the saw. Now turn the motor on and press it down and see how the blade guard goes up.
Have fun with it. You may put it on the internet but you must give credits to me.
18 Comments
cooljupjup 11 years ago
MrShadowKnight16 11 years ago
Knexman15 12 years ago
CassisDude98 12 years ago
Thanks for my 50th comment!!!
Snosageman99 12 years ago
Also Thanks for the 5 stars!!!!
kelseymh 12 years ago
Putting the link for the YouTube video is great; you can also, if you want, embed the video directly into your I'ble. Use the little "filmstrip" icon to get a popup box, where you paste the embed XML from YouTube. On the YouTube side, make sure you select Use old embed codes, because I'bles software doesn't know how to parse the new iframe syntax.
koenco007 12 years ago
beanieostrich 12 years ago
~KGB~ 12 years ago
~KGB~ 12 years ago
