K'nex Oblivion Ball Machine Instructions
Intro: K'nex Oblivion Ball Machine Instructions
STEP 1: Piece Count
RODS:
grey: 94
red: 196
yellow: 458
blue: 878
white: 401
Green: 778
CONNECTORS:
white: 97
blue 3d: 265
purple 3d: 603
yellow: 452
green: 24
red: 314
orange: 110
light-grey: 14
dark-grey: 209
SPECIAL:
orange track connector: 159
Black or tan rod: 3
Purple flexi-rod: 22
orange flexi-rod: 3
tan lock: 19
blue clip: 25
Y clip: 78
blue spacer: 113
silver spacer: 129
track clip: 6
medium tire no tread: 11
small tire: 4
red gear: 6
small blue gear: 1
yellow gear: 1
motors: 3
triangle panel with three holes: 1
chain link: 142
tubing
string
GRAND TOTAL: 5,621
grey: 94
red: 196
yellow: 458
blue: 878
white: 401
Green: 778
CONNECTORS:
white: 97
blue 3d: 265
purple 3d: 603
yellow: 452
green: 24
red: 314
orange: 110
light-grey: 14
dark-grey: 209
SPECIAL:
Black or tan rod: 3
orange flexi-rod: 3
tan lock: 19
blue clip: 25
Y clip: 78
blue spacer: 113
silver spacer: 129
track clip: 6
small tire: 4
red gear: 6
small blue gear: 1
yellow gear: 1
motors: 3
chain link: 142
tubing
string
GRAND TOTAL: 5,621
STEP 2: Base and Supports
Let's start building!
STEP 3: Return Path
STEP 4: Main Support and Lift
STEP 5: Secondary Supports
STEP 6: Path Selecters
STEP 7: Path 1- the Drawbridge
This step really isn't step-by-step based because I just put in a lot of pictures of the thing but I assure you you will be able to make it from them. There are four pulley systems and one mother switch. The process of the cycle goes like this:
1. The ball hits the mother switch and the bridge starts to lower down.
2. The bridge being at the bottom triggers motor 2 which is only there to pull the mother switch up which makes the bridge rise.
3. The bridge rises until the pulley in the back pulls the mother switch back down into the off position. Motor 2 automatically shuts itself off.
Yes, I give credit to the member who made the "Leave Me Alone Box" because motor two uses the exact mechanism.
Take your time with this, it is very easy to lose track of where you are. The pulley systems will take a little while to adjust so don't get impatient with them.
STEP 8: Path 2- the Wheel
This path contains the large wheel at the center of the machine.
STEP 9: Path 3- Double-Path
This path includes a new element that isolates the balls and spaces them farther apart.
31 Comments
MisterBukweet 10 years ago
knexpert#10829476 9 years ago
AWESOME!
collinjo12 10 years ago
MechanicalCreationMaster 10 years ago
Great job, this machine is really cool! I really like the drawbridge element; I have tried something like this before but never got it to work. Between you and Shadowman39 I'll have to learn the art of mechanical automation!
So keep it up with your machines and let us have some more innovations! Now you see why bigger is more fun? ;-)
alexf1 10 years ago
johnwallacemurray 1 year ago
radical28 3 years ago
kimmy0923 8 years ago
tckinney951 8 years ago
iis there any way that you can show all of the hookups for the 2 motors you don't get a good view of the inside of the machine by the motor its very frustrating if you could please just show me the way the on off mechanism works thank you tim
knexpert#10829476 8 years ago
There are new instructions for the bridge alone now:D
javive_7892 9 years ago
can you post more pictures from inside connection for the motor that is on the middle of the drawbridge step 7 its hard to see the inside parts, THANKS
knex akbar 10 years ago
does this work with the newer knex balls aswell?
knexpert#10829476 10 years ago
Knex2thelimit 10 years ago
hunter999 10 years ago
