Introduction: Knex Rifle / Sniper Rifle
First instructable - comments welcome
special thanks to Knexartillerys RPG for the main mechanism,
I've turned it into a Sniper rifle.
PROS:
Practical stock
Easily customizable
True trigger
Moderate amount of pieces
Very powerful
CONS:
Slow to reload
Some what flimsy, but can be reinforced
SPECS:
Slingshot type gun
Shoots approximately 100 feet (depending on elastics used)
Room for scope
PROS:
Practical stock
Easily customizable
True trigger
Very powerful
CONS:
Slow to reload
SPECS:
Slingshot type gun
Room for scope
Step 1: Parts
Overview of parts needed:
Step 2: Barrel
1. Assemble
2. put these in
3. front image
4. thats the ball joint connector on a white (black) rod in between the first 2 yellow connectors
2. put these in
3. front image
Step 3: Stock and Trigger
1. assemble
2. assemble
3. assemble
4. assemble
5. attach number 2
6. attach number 3
7. attach number 4
8. put trigger assembly together
9. " "
10. insert trigger
2. assemble
3. assemble
4. assemble
5. attach number 2
6. attach number 3
7. attach number 4
9. " "
10. insert trigger
Step 4: Firing Pin
1. assemble pin
Step 5: Putting It Together
1. connect the stock to the barrel assembly
2. insert the pin
2. insert the pin
Step 6: Preping and Loading
1. putting on the stocks elastics
1) holds the trigger forward
2) holds the trigger up and the firing pin elastic down
3) firing pin elastic
2. making barrel's elastics
3. " "
4. putting on the barrel's elastics
5. loading
3. " "
5. loading
