Introduction: Knex Gun
This is version 2. It uses a fair amount of pieces.
Features:
True-trigger
Bullet holder to make it shoot farther
Accurate iron sights
35-40 feet range with two 64# RB's
More power than the 1st version
You can put as many bands as you want onto the ram but it will be really hard to pull back if you put more than 4 RB's on each side.
Cons:
Small handle
Bullet spins out of control sometimes when shot
If you need help, just tell me and i'll eat you.
Features:
True-trigger
Cons:
Small handle
Step 1: Parts
Connectors:
White: 6
Yellow: 4
Green: 6
Orange: 17
Blue knob: 3
Brown knob: 6
2 slot gray: 7
1 slot gray: 6
Hinge: 1
Y connector: 2
Rods:
White: 30
Green: 12
Blue: 1
Gray: 1
Random:
Blue spacers: 22
Gray spacer: 4
Tape
Rubber bands
White: 6
Yellow: 4
Green: 6
Orange: 17
Blue knob: 3
Brown knob: 6
2 slot gray: 7
1 slot gray: 6
Hinge: 1
Y connector: 2
Rods:
White: 30
Green: 12
Blue: 1
Gray: 1
Random:
Blue spacers: 22
Gray spacer: 4
Tape
Rubber bands
Step 2: Handle
1. What you'll be building
2. Build. Note the tape
3. Build
4. Put step 3 onto a big panel of step 2. Make sure the tape is facing outwards.
5. Put the small layer of step 2 onto step 4
6. Finish it up.
7-9. This is the big handle. Build this if you have big hands. You should be able to build it by the pictures.
3. Build
6. Finish it up.
Step 3: Barrel
1. This is what you will be building.
2. Build
3. Build
4. Build
5. Build
6. Build
7. Gahh... build (I should have put 2-7 build...)
8. Get these oranges. There are 13. I secretly put them in groups :) Do you see the groups?
9. Put a orange and step 3 onto step 2.
10. Put step 4 onto step 9
11. Put step 5 onto step 10. Don't forget the orange connectors.
12. Put step 6 onto step 11. Again, don't forget the orange connectors. Not like you will though...
13. Put step 7 onto step 12.
14. All done
2. Build
3. Build
4. Build
5. Build
6. Build
14. All done
Step 4: Trigger
1. The Trigger
2. Make and gather
3. Attach like so
4. Add the 2 slot gray connector in the middle with the white rod
5. All done
2. Make and gather
3. Attach like so
5. All done
Step 5: Putting It Together
1. Umm. Remove the green connector (any) on the handle. remove the loose white rod and the 2 slot gray connector on the trigger. Then add the gray connector onto the middle part of the handle like the picture.
2. Put the trigger and alline them with the hole of the gray connector and the trigger. then put the white rod through.
3. Put the green connector back on.
4. Add the handle to the barrel. Also make sure the blue knob goes in the opening in the barrel.
5. Make the ram but use a black gray rod if you have one. I forgot and used a normal gray rod. :(
6. Put a blue spacer in the hole like shown.
7. Slide the ram in and make sure you get the blue spacer on.
8. Add the rubber band onto the trigger. It wraps to the other side.
9. Add the 64# rubber bands onto the ram and onto the barrel like the picture.
10. How to load.
11. Another way that gets futher distance
12. All done
10. How to load.
12. All done
