Introduction: Knex Shotgun
Hello, and this instructable is to show you how to make AdamsDead's Shotgun. I know you have all been waiting for a long time now. Well its because I've been busy with school and stuff. So I hope I have enough Pictures and they are clear enough. :)(Mods)
Step 1: Trigger
This is the trigger for the gun obviously. You may recognize it.
Pic 1: Make This.
Pic 2: Make That.
Pic 3: It's Different from pic 2 so make that.
Pic 4: Connect Pic 2 and 3 in the correct places. Also add the gray rod to the green connector in Pic 2.
Pic 5: Attach Pic 1 to the gray rod in Pic 4.
Step 2: Barrel and Hopper.
THis will tell you how to make the barrel and hopper for the gun.
Pic 1: Make.
Pic 2: Just there to help you make pic 1.
Pic 3: Make. ( Not Hard )
Pic 4: Other side of Pic 4.
Pic 5: Attach as seen in the Picture.
Pic 6: (Yes I know I forgot to add this before the Hopper).
Pic 7: Again there to help you make Pic 6.
Pic 8: That part is crucial.
Pic 9: Connect Pic 6 to Pic 1.
Pic 10: It should look like That.
Your done with this section. :)
Step 3: Firing Pin and Pump
This part shows you how to make The pump and firing pin.
Pic 1 and 2: Make.(Same thing)
Pic 3: Add 2 grey rods with 3 blue spacers.(Grey rods are the guides.)
Pic 4 and 5: Make.(Same Thing)
Pic 6: Put Pump on like so.
Pic 7:How to attach it to barrel.
Step 4: Body and Stock
THis is the Body and the Stock.
Pic 1: Make.
Pic 2: Make another Pic 1 just add the orange connectors in the right place.
Pic 3: Fully connected.
(I would suggest Not connecting the stock and body till after everything else is connected.)
Pic 4,5,6, and 7: Make This. It's 5 layers thick.
Step 5: Attaching It All Together and Rubber Band Placement.
OK this is the easy part.
Pic 1: Attaching the Trigger.
Pic 2: Slide it in there.
Pic 3: Slide the other half and connect the two.
Pic 4: It should look like that. NOw you need a Blue rod.
Pic 5: A little blurry but insert it like so.(Make sure it clicks)
Pic 6 and 7: Attach barrel, pump, firing pin, and guide like so.
Pic 8 and 9: Attach stock.
Pic 10: Attach rubber band for trigger here.
Pic 11 and 12: Pump rubber band goes here.
Pic 13:
Step 6: Finished!!!!!!!!!!!!!
Now have fun with your new shotgun. I will like to give thanks to AdamsDead for letting me post his gun. Now please if anyone could let me now if I did something wrong or forgot something please don't be afraid to tell me. Well Have Fun :).
123 Comments
8 years ago
what is that yellow piece on step three pic four and five
8 years ago
10 years ago on Introduction
oh ya do recongnise trigger from well its slightly modded from the ednators pump action p90 btw i am trying to make this and dat at same time lol
sorry instructables just glitched and made me post 3 times
This is an adamsdead shotgun not ednator
12 years ago on Introduction
Not bad on it's own, but it looks and works a lot like the OSNJCKMA2, without adding a lot of extra stuff the OSNJCKMA2 didn't had. Normally, a 2.5 for the low innovation factor, but a 3.0 because of the mods. Oh, and by the way, maybe you should change the main picture.
wrong its adamsdead52's gun
is this really airsoft
hmm wats the range
10 years ago on Step 2
w8 use ball sockets from a knex man
is it ok if i use tan clips
11 years ago on Introduction
How did this end up in the airsoft section? And I like Slayer better than slipknot.
Reply 11 years ago on Introduction
Amen.
LOL ok man =D I have a new forum topic.
I mean amen to slayer being better than slipknot
OH YEA!!!!
great gun just to let you know there is one flaw to your mag ... and that is that it alwas jams. but i have made a anti jam mag that i can show you if you want, it holds aprox: 15 blue rods but other than that BRILL GUN !
11 years ago on Step 3
is that white rod needed on picture 2?
