Knex 'Slider' Ball Lift
Intro: Knex 'Slider' Ball Lift
This lift is quite like the 'alternator' lift, but at a 45 degree angle. It's also a lot more piece efficient.
It is also easily modified to get higher.
Video: http://youtu.be/LB3ykR_vr-I
STEP 1: Making a Scaffold
This scaffold will be made of 'cubes' and a slope down the side.
Part of the scaffold is left out, on the black rods around that there are dark grey connectors.
There is also a small ramp at the orange connectors, a yellow connector at the top, and extra base at the bottom, front.
STEP 2: Moving Part
This is the bit that slides up and down.
STEP 3: Adding That
Clip the previous step onto the dark grey connectors in the gap.
STEP 4: Roof
This is the part that goes above the slider so the ball doesn't go down.
STEP 5: Attaching the Roof
Attach each of the blue rods to the scaffold.
STEP 6: Entrance Track
This is where the ball enters the lift
STEP 7: Adding the Entrance
There are six places to connect the green rods.
STEP 8: Motor Parts
This is the crankshaft and the motor.
STEP 9: Putting It Together (Finished)
There are five connections to make.
STEP 10: What If Your Slider Is Jamming?
Put a spacer on any of the red rods like in the pictures.
19 Comments
KnexXHyperX 10 months ago
Knexified 2 years ago
mathsboy314 2 years ago
KnexXHyperX 2 years ago
jonlukepenci26 5 years ago
mathsboy314 4 years ago
I designed this lift so you can extend it to any size.
You also can skip steps 6-7 (the entrance track) and let the ball start anywhere.
Step 1 (scaffold) is only a suggestion, and should be replaced according to the design of your ball machine.
For these reasons, it's hard to determine how many pieces are needed.
bennett2198 6 years ago
I made this. It works very well. I like the way it pushes the balls up. I made a video of it lifting up 3 balls at a time. It handled them quite well.
MechanicalCreationMaster 11 years ago
mathsboy314 10 years ago
MechanicalCreationMaster 10 years ago
knex N craftin apocolypse 10 years ago
Smackythenerd 11 years ago
sandroknexmaster 11 years ago
It took me only half an hour to build.
daredevil499 11 years ago
KneXtreme 11 years ago
