Knex Lightsaber Design
Intro: Knex Lightsaber Design
Hello there,
I made a knex lightsword design. Due interest I decided to post instructions for this. Its the first instructable that I have made, so if something is unclear or not good, feel free to say so :)
P.S. Im not English :d
Part list:
4 black rods
4 small grey gears
4 grey connectors
1 small wide wheel
2 orange connectors (in brown)
3 white connectors (in black)
8 red connectors (in grey)
2 yellow connectors (in white)
9 white rods (in black)
3 green rods (in black)
2 yellow rods (in grey)
1 black rubber band (from trekker set I think)
1 red knex man hand
yellow blade:
32 yellow connectors
31 yellow rods
white blade:
43 white connecters
88 white connecters
3 grey rods
13 grey connecters
This has been a really fun project to do!
I hope you liked it :)
Please Rate & Comment :)
And Be Creative!
~ Kairah ~
Part list:
4 black rods
4 small grey gears
4 grey connectors
1 small wide wheel
1 red knex man hand
yellow blade:
31 yellow rods
white blade:
43 white connecters
88 white connecters
3 grey rods
13 grey connecters
And Be Creative!
~ Kairah ~
STEP 1: Step 1: Making the Handle
Follow pictures:
Put the two gears on the small black rod, and place it between the two large rods.
STEP 2: Step 2: Making the Handle
Follow pictures.
STEP 3: Step 3: Making the Handle
Now you add two black rods.
- Slide all parts to one side.
- Connect the black rods to the black snowflake and gray 3-connectors.
- Slide those to the left and connect the next parts, repeat this until the black rods are connected like picture 7.
STEP 4: Step 4: Making the Handle
Follow Pictures.
Picture 2/3/4/5
connect a gray 1-connector + small black rod to the black snowflake, with the gray connector holding the gears in place.
Do this at all gears
Picture 6/7
Slide in a gray (yellow) rod in the two 3-connectors on both sides.
Picture 8
It should look like this.
Picture 9
Make this.
Picture 2/3/4/5
Picture 6/7
Picture 8
Picture 9
Make this.
STEP 5: Step 5: Making the Handle
For this part you need the "red knex man hand" like the ones shown in the first picture. And make the parts in the second picture.
Put them on the ends of both small black rods that you added in step 4.
STEP 6: Step 6: Making the Handle
Ok, now you need to take the parts made in step 4 and put the rubber band on it as shown in picture 2 and 3. Then connect the parts to the handle. You can either have the rubber band on the front or the back of the handle. I put them on the back.
STEP 7: Step 7: Making the Handle
Take a small and wide wheel, put a small black rod on it (not shown on the picture). Then slide the tire off the rim just a bit, so it will fit around the black snowflake on the end of the handle.
And the handle is done! :D
STEP 8: Step 8: Making the "Laser Light"
I did the yellow laser with yellow rods and connectors. Just snap some together, but make sure that you keep two rods sticking out on one end so you can put the handle on there.
Tip: If you dont want to break your fingers on this... use a screwdriver to push some parts on :)
STEP 9: Yay! Its Done!
STEP 10: Some Variations
Here's some other variations that i made.
I put a white blade on it. and replaced the two gray (yellow size) rods and the two pieces that are on the gears with 3 bendable red rods, which looks pretty neat :D
38 Comments
Ace123 2 years ago
Knexchampion 3 years ago
super knex builder 12 years ago
k-n-e-x(leaved ibls) 13 years ago
the master 2 13 years ago
NatNoBrains 13 years ago
hedzup456 13 years ago
That would be sweet
Im building know!
YAY!
I hope you listen to my idea
i have to stop talking know
bye
Kairah 13 years ago
osi 13 years ago
Randomguy65 14 years ago
Senior Waffleman 14 years ago
Shadowman39 14 years ago
Kairah 14 years ago
s0lekill3r 14 years ago
Kairah 14 years ago
jawlecks 14 years ago
Dante9030 14 years ago
