Knex Vintage F1 Car
Intro: Knex Vintage F1 Car
This is an F1 car that I built out of knex. It has independent suspension and steering and looks like a car from 1967/1968.
The suspension is actually the flexibility of the knex under load but you can put real springs in place of the spacers on the suspension.
STEP 1: Front Suspension and Steering
Make all of this stuff and just follow instructions.
STEP 2: Front Frame
This is the front of the frame and attaching the front wheels.
STEP 3: Driver Tub & Engine
This is where the driver sits and the engine. The engine is a V8 with individual carbs and air filters.
STEP 4: Rear Suspension
This is the rear frame and suspension. Almost done!
STEP 5: Putting It Together
STEP 6: Wings
In 1968 F1 cars were allowed to have wings. Teams put the wing struts on the suspension to improve grip but that caused failures of the aerofoils. The next year the wings had to be mounted to the frame. This car has wings that would be found on a Lotus 49B.
STEP 7: Modifications
A few months ago I heavily modified the car.
Excuse the dust, it was in storage.
What I changed was the rear suspension, I moved it closer to the front of the car.
I also change the rear end, and put in a mock transmission.
These pictures are of the car in non-wing 1967 spec, and winged 1968 spec.
I think that the modification really helped with the looks of the car.
39 Comments
Imperar 3 years ago
BasketballProdigy14 8 years ago
knex dude 2000 11 years ago
JUST WATCHED YOUR VIDEO " CRASH LANDING " TIPS TRY IT WITH AN R.C CAR INSTEAD .
jmoore11 11 years ago
The problem with crashing is that the car had no brakes, you can see that the tow string is attached to the steering column, so if the car goes off course it will steer itself back on target.
I've almost solved the braking problem, it uses a system that releases the brakes when the car is being pulled, and then when the bike slows down, the brakes on the car engage. I just have to test it on the road, there's a lot of snow though, so it will have to wait for a few months.
In the meantime I'm painting a paper mache model of a Toyota GT-One that fits over top of the car.
It's a model of this.
http://encarsglobe.com/data_images/models/lotus-49/lotus-49-04.jpg
MK3424 11 years ago
More impressive is the fact that it's still alive!
They are still racing online, building tracks and custom carsets and seasons.
After playing GPL for a bit I decided to make a car that looked a bit like the ones in the game.
MK3424 11 years ago
But a few months ago I heavily modified it, and it looks WAY better.
The pics will be uploaded in just a moment.
Edit: New pictures are up, go to the last step.
MK3424 11 years ago
It even persuade me to wants to even play more GPL!
MK3424 11 years ago
I maybe will modify it, so it will be sturdy enough to handle my g27; or later in life a Fanatec wheel.
And how did you make something strong enough to hold a wheel?!?
Even my 1 inch steel square tubing still moves a bit.
MK3424 11 years ago
In manufacturing class I'm right in the middle of making a base for inverted G25 pedals, and if I can get a steering wheel, then I'll make a hub adapter as well.
MK3424 11 years ago
Even with the rubber feets it moves alot becaus instead of padel distance it use pedal pressure for the brakes and thats why it moves alot.
I guess you would need either wood or metal to prevent it from shifting while you drive.
MK3424 11 years ago
maybe i will put it on wood or metal.
but maybe in the future i will get a pleichair from pleifactory with the pedal base so that the pedals won't move.
http://sphotos-a.ak.fbcdn.net/hphotos-ak-ash4/407996_330290363678242_1167939855_n.jpg
I made that in my manufacturing class last year, it's a world of difference when you compare it to just clamping it on a table. (Inverted pedal base is almost done.)
MK3424 11 years ago
I can only clamp my wheel(s) on my desk and hope that they won't move around.
I also have prevent my desk chair from moving around.
Hopefully you can rig up something to hold your gear. :tup:
