Knex 'Weighted Kick' Ball Machine Lift/element Hybrid
Intro: Knex 'Weighted Kick' Ball Machine Lift/element Hybrid
This is a lift which uses an element to reset it, so there's no motor involved. Unfortuantly the reset element looses more height than gained by the lift, so it's more of an element.
Video: http://youtu.be/Bta4ciw_hWk
STEP 1: The Base
_ _ _
|\ |\ | | Double layered
| \| \| | Connected by
------- Blue rods
------- Blue rods
STEP 2: Enterance Track (and 2 Small Parts)
The entrance track goes on the part where there a square from the top view.
The 2 extra parts are composed of a white connector and 2 yellow rods each.
STEP 3: First Hinge
This hinge fits into the 2 extra parts of the previous step. This connects the counter weight hinge and the arm hinge.
STEP 4: Continued Scaffold
Again, a pattern with 2 layers connected by blue rods. Look out for the extra parts (tagged).
STEP 5: Part Connecting Hinges
This would be a rod... if any rod was this length.
STEP 6: Half of the Top Layer of Scaffold
This layer includes a path. Try to keep it out your way while building.
STEP 7: Parallelogram 1
A parallelogram is a quadrilateral with both pairs of opposite side equal.
A parallelogram is also a quadrilateral with both pairs of opposite parallel.
That's how this (and other elements) can function.
STEP 8: The Arm
Again, double layer (but connected differently this time). If you want you can add extra scaffolding between the entrance and everything else.
STEP 9: More Scaffolds
This part will hold the part which holds the second hinge.
STEP 10: Even More Scaffolds
This path will hold the second hinge.
STEP 11: The Second Hinge Part 1
This part will connect to the scaffold. Pay attention on the orientation of the orange bit.
STEP 12: The Second Hinge Part 2
This bit goes on the end of the second hinge. It holds the counterweight.
STEP 13: Adding the Second Hinge
Once you have completed this step push all the pieces (starting from the tagged one in the 3rd picture) towards the grey connector sticking out on the opposite side.
STEP 14: The Rest of the Scaffold
This is customizable. Make your own or copy mine.
STEP 15: And Even More Scaffold
This part holds the reset element.
STEP 16: Pac-Man Counterweight
Pac-Man is the right shape and size for the mechanism. Sometimes pieces come in different colours including yellow...
STEP 17: Reset Arm
The ball pulls this down, pushing up Pac-Man, raising the orange lever, setting the counterweight, resetting the unbalanced ramp. Try it... hmm... the ball needs more force...
STEP 18: Adding a Chute for More Force
Unless the previous element gives enough force, the ball won't be able to reset the lift.
STEP 19: Done!
Congrats! You're finished!
11 Comments
koolcoasterkid 10 years ago
hawk45 10 years ago
knexpert#10829476 10 years ago
sandroknexmaster 10 years ago
I also have an idea to make this a lift, well, sort of a lift:
First one ball enters the arm and waits for a second ball. Then the second ball enters and the arm moves like in the vid (You probably have to add more counterweight)
Then you build a seperator (I think it's best to make a horizontal switch so you don't lose a lot of height) One of the balls, let's say the one that goes to left, continues its path like the first ball in the vid. The second ball, that goes to the right, falls back down and resets the lift like the second ball does in the vid, and then it rolls back to the entrance and waits for a second ball.
So both balls enter at the same place, and there is always one ball waiting in the arm.
If you place some of these mechanisms on top of each other, you can make a self-resetting ball machine lift without a motor.
I know it sounds very difficult and I'm absolutely not sure if it's possible, it's just an idea that came up in me.
mathsboy314 10 years ago
BUT...
A third ball from a separate track could help the second ball if you don't want them to loose too much height, and possibly they head to entrance where they both go up. Perhaps a forth ball also helps but it enters the entrance track after it has already gone up.
I just lost my train of thought. Good luck! (No pressure, but I'm expecting you to modify this the most resulting in a path selector.)
dickheijboer 10 years ago
Shadowman39 10 years ago
hunter999 10 years ago
Sorunome 10 years ago
MechanicalCreationMaster 10 years ago
