Knex Grenade With Firing Pin
Intro: Knex Grenade With Firing Pin
A simple yet effective grenade. It has a "door" in front, a hatch for putting ammo in (on the back), and a pin that is locked in place. This grenade is also very small and easy to build (perfect for beginners).
STEP 1: Required Pieces
To make this grenade, you need:
Rods:
white: 3
Blue: 2
Yellow: 4
Connectors:
Grey, 1 slot: 3
Yellow, 5 slots: 6
White, 8 slots: 3
Misc.:
Black "Y" connector: 2
Black socket connector: 1
Tan connector: 2
Grey spacer: 1
Rods:
white: 3
Blue: 2
Yellow: 4
Connectors:
Grey, 1 slot: 3
Yellow, 5 slots: 6
White, 8 slots: 3
Misc.:
Tan connector: 2
Grey spacer: 1
STEP 2: Building the Body
Yeah... pretty self-explanatory.
STEP 3: Building the Door
Again... easy peasy.
STEP 4: Building the Pin and Hinge
Yeah... easy.
STEP 5: Building the Hatch
>_> need any more explanation?
STEP 6: Putting It Together
Attach like so. The bottom of the door (the side without the gray connector) should just rest into the y connector on the body. When the door is in place, push the pin through until it clicks into the socket connector. (images 2 and 3 are different angles.)
STEP 7: Loading the Grenade
You are finished! To load the grenade, push up the blue part of the door, insert green rods, and close the hatch. When you are ready to throw it, hold the grenade vertically in your right hand with the door facing away from you. Next, pull the pin slightly towards you, and then out. This will release the door. Finally, chuck it at your target. Have fun!
62 Comments
benjamin2006 8 years ago
coooooooooooooooooooooooooooooooooooolllllllllllllllllllllllllll! im about to build
SonicX 22 13 years ago
mberg 13 years ago
mberg 13 years ago
skate31 13 years ago
a_person 13 years ago
H1T4TCH1 13 years ago
fauge7 14 years ago
made i made 2
luckyone 14 years ago
thomaswatton 14 years ago
chopstx 14 years ago
IAC's Wart bomb..................
Please help!
An Villain 14 years ago
