Knex Lever-action Shotgun/rifle
Intro: Knex Lever-action Shotgun/rifle
This is my first instructable so be nice. Anyway this gun features:
1. Removable mags, courtesy of Killer_Safe_Cracker
2. A lever mechanism for ease of cocking (I know it isn't true lever action as it doest chamber a shot like a bolt action).
3. A wide barrel that enables multible shots to be fired like a shotgun.
4. Easy to add parts on the inside due to pins that can be removed easily
Con's
1. low range
2.low ROF
3.mags can be hard to preload
Con's
1. low range
2.low ROF
STEP 1: Outer Body
1+2: make this (part 1)
3. add blue rods
4. make this
5 thread on to part 1
3. add blue rods
4. make this
STEP 2: Innards
1. Make
2. make
3. attatch
4+5. make this
6. make these
7.put them together
8.slot it in
9. add it on
10. close-up
11. clip the other one on
12. make
13. add
14. put in a green rod
15. add the other part
16. make
17. add
18. make 2 of these...
19. and one of these
20+21 add in order (put the other small one on too after.)
22. make
23.add
2. make
3. attatch
4+5. make this
6. make these
7.put them together
8.slot it in
9. add it on
10. close-up
12. make
13. add
16. make
17. add
22. make
23.add
STEP 3: Trigger
I was lazy here but it should be easy
1-3 various views of the trigger
4. attatch
Note: the broken rod isn't necessary replace the two black hinge pieces with a normal hinge and apply tape
4. attatch
STEP 4: Lever and Pin
1. the pin (the string is 1 length approx 60cm long + tying space.)
2-4. the lever
5. don't forget the grey connector
6. insert pin
7. clip on lever
8. add the other shell
2-4. the lever
6. insert pin
7. clip on lever
STEP 5: Stock
1+2. build. The 4 blue spacers can be replaced with 2 small wheels
3. attatch
4. loop the strings over the wheels
5. build and set aside
6. build
7. remember the correct spacer placing
8+9. put them together
10.add it to the body
11. another view
12. make these supports
13. attach them
3. attatch
6. build
11. another view
13. attach them
STEP 6: Outer Panels, Sights, and Bands
1+2. make this big panel
3. attatch it
4. put bands on the trigger
5. put bands on the pin
6. make these sights
7+8. put them on
3. attatch it
7+8. put them on
STEP 7: Mag
I was lazy again. It uses the mag from the TBAR just without the stuff on top
link: https://www.instructables.com/id/TBAR-Thunder-Bolt-Assault-Rifle-1/step12/Mag/
6 Comments
cazadactle 12 years ago
beanieostrich 12 years ago
apples!!!!! 12 years ago
The Chunky Sniper! 12 years ago
ooda 12 years ago
