Knex Motor Modification
Intro: Knex Motor Modification
Are you having the red battery motor of knex and are tired of changing batteries all the time? This is the solution! With this you modify the motors to ones to be plugged in!
STEP 1: Gather Materials
First gather the materials.
STEP 2: Prepare the Cable
First you preper the cable.
STEP 3: Unscrew the Motor
Now you unscrew the motor. You just need that red half.
STEP 4: Prepare the Red Lead
Veary simple, just screwing a hole.
STEP 5: Using the Soldering Gun
Soldering gun
STEP 6: Putting It Together
After you made this step you'll have to put 3Volt on the other end of the cable. Polarity is irrelevant because it still goes through the switch.
28 Comments
FanPlastic 8 years ago
I really want to do this now
suparman 9 years ago
i like this is blog
http://indo-modif.com
Orangeprofessor 12 years ago
Sorunome 12 years ago
You must know that you are just adding a new function to your motor when making this.
The modification is just as if you'd put at the contacts where the batteries are the wires.
HamenChips 12 years ago
How much miliamperes does your adapter produce at 3 volts?
Better if you use smaller ones because the one you're using is very powerful it could burn a motor in minutes, mine is about 150Ma and it smelled bad after minutes of testing.
hedzup456 13 years ago
Sorunome 13 years ago
Tornado96 13 years ago
Nice ible though! 4.5*
Shadowman39 13 years ago
