Introduction: Knex "hurricane" Pump-action Shotgun
hello this is the hurricane shotgun. if you have any questions feal free to ask.my last instructable got allot of comments that were not nice so please be nicer. If any one is wondering a Pump-action gun in a gun that there is a foregrip that you pull back and it pulls back the ram-rod. dont forget to rate! if you want to mod and post please conntact, me thank you.
1. the shotgun it-self
2.the barrel
3-4. yay mods remove old mag and put in this one it works allot better also make sure that the red connectors connect to the innards of the barrel it fires white rods
2.the barrel
Step 1: The Pump
this is the pump to cock the gun
1. the main part of the pump add tape to the grays
2. 2 red rods
3.slide through the holes
2. 2 red rods
Step 2: The Body and the Handle
Here you will learn how to make the body or frame and the handle
1. both sides of the handle add 2 gray or 6 blue spacers to each blue rod that is sticking up
2. attch them together
3. other side
4. stock
5. handle connecting place
6. a little further
7. the rest
8-10. the side with blue rods and orange connecters
11. atach like so
12. connect handle here
13. atach pump here
3. other side
4. stock
6. a little further
7. the rest
11. atach like so
13. atach pump here
Step 3: Trigger
the trigger keeps the gun from fireing to soon
1.the pieces
2. build this
3. and finish it
1.the pieces
2. build this
3. and finish it
Step 4: Barrel an the Magazine
the mag auto loads the barrel
1. the finished barrel and mag
2. the innards of the barrel
3. the outside of the barrel
4. the upper inards
5. lower inards
6.cover them up
7. attach the green conectors with the black hand clips
8.the inards and the mag pusher
9. the 2 sides
10. slide on
11. cover with other side
12 . atach here
4. the upper inards
5. lower inards
6.cover them up
9. the 2 sides
10. slide on
12 . atach here
Step 5: Ram-rod
the ram rod pushes the bullet out
1 build ( 6 tan clips nessesary)
2 close up
2 close up
Step 6: Connect Them All Together and Adding Rubberbands
connect them and once they are you are done!!!
1 ataching barrel to frame
2. ataching trigger
3. ataching ramrod slide it trough the slides grey connectors
4 add rubberbands to trigger and magpusher not on pic but and a rubberband to the ramrod
2. ataching trigger
