Knex Arm Gun Made by S0lekill3r.
5,149
17
81
Introduction: Knex Arm Gun Made by S0lekill3r.
About: Supdoc. Member for 9 years. o.o
Hello, this is s0lekill3r's arm gun all the credit goes to him because I did not make it. He also said I have permission to post.
STATS
1.Pump action.
2.Block trigger.(It is OK the way this gun is.)
3.Good sight.
4.Magazine it holds like 12 blue rods or so.
5.Put your arm inside DUH.
6.Cool-ish mechanism.
7.Shoots about 30 ft.
Step 1: Parts. (MAY BE a BIT OFF)
Parts.
38 Big green rods.
1 Roller Coaster splicer from the oldest ones.
32 Gray rods.
7 Snowflakes.
19 Orange connectors.
32 Green connectors.
2 Y connectors .
3 Decapitadeds.
2 Blue rods.
16 Blue spacers.
16 Dark gray connectors.
10 Blue tabs.
6 Green rods.
1 Black ball socket.
1 Tan red rod .
35 Blue connectors.
9 Silver spacer.
3 Tan clips.
64 5 way connectors.
5 light gray connectors.
80 White rods.
Duct tape.
As many rubber bands as you want.
361 Parts all together including duct tape and rubber bands.
Step 2: Here Is the Barrel and Ram. (It's a Block Trigger.)
1.Ram.
2.Inside.
3.Higher view of inside.
4.Side view.
5.Bottom view.
6.It's upside down view.
7.Diagonal view.
8.add this gray connector.
9.Insert ram.
Step 3: The Very Front of the Gun.
Just build off the pictures :)
1.Part of the pump.(Replace the blue rod with a yellow rod it will make it better.)
2.More pump.
3.Another view.
4.Build.
5.Put that together.
6.Put that together.
7.Now connect everything.
Step 4: Make All of This Big Step (I Hope Its Not to Hard.)
Good luck.
1.Make all of these.
2.Make.
3.Another view.
4.More views.
5.Just showing you the pattern up close
6.This is a different piece.
7.Another view
8.Another view
Step 5: Connecting and Rubberbands WOOOO!!!!!
1.Put them on.
2.Another view.
3.now connect the front.
4.Another view.
5.Now add the front piece on.
6.Another view.
7.now connect that front part on to the barrel.
8.Tape that.
9.Another view
10.Tape the ram..
11.Now put the ram through that one one piece.
12.Put that band on.
13.Put Another band on the other side.
Be the First to Share
    • Sculpt & Carve Challenge
    • Build a Tool Contest
    • Backyard Contest
      Backyard Contest
    81 Comments
    cholden
    cholden
    Reply 11 years ago on Introduction
    agrey rod is the same size as 2 yellow rods on opisite side of a connecter
    Vynash
    Vynash
    Oooook... what if you smiled and didn't have a nose? :-F
    novakfor3
    novakfor3
    Cool! I like the design. Could be something out of Iron Man !
    Vynash
    Vynash
    Reply 12 years ago on Step 2
    ??? this is worlds easiest creation ???
    knexbuilder12345
    knexbuilder12345
    12 years ago on Step 5
    do you think you could show a better explaination of how to put the barrel in the gun that would be great thanks
    Vynash
    Vynash
    Reply 12 years ago on Step 5
    It's not very hard, keep trying if you haven't got it yet :)
    I can hardly remember how =O
    1. tennis ball 2. a lamps base 3. there is another piece right there but it's not important. 4. OBOYOBOTOBOYOBOYOBOY... 5. hi 6. hello 7. hey 8. heyo 9. hey 10. muuhahahahhaahahhhahahaha 11. hey 12. hey 13. blah 14. blah 15. blah 16. dude stop 17. hey 18. your head explode 19. lolz 20. lolzeramma 21. roflcopter 22. rofledoctor 23. rofle 24. stop 25. dont try 26. ha 27. easy 28. easy 29. was up done! ive read them all
    Duct Tape Dude
    Duct Tape Dude
    Reply 12 years ago on Introduction
    You Missed Some... 2.Just look At That Sight 3. Add me!
