Introduction: Knex Pencil/ Single Rod Shooter!(11pcs)
an 11 piece knex weapon. Shoots pencils- grey rods, red rods, anything you want thats skinny and long! Results.With strong RB.. Worst-20ft Best-56.5 feet
Step 1: Part One. the Pieces.
You'd never guess. Get the parts :3
3 blue rods
2 orange connectors
2 yellow connectors
2 grey clips
1 strong RB (will not snap if pulled about 10 inches, though.
3 blue rods
2 orange connectors
2 yellow connectors
2 grey clips
Step 2: Part 2. Body Assembly.
Make the first picture. Then, add grey clips to each end of a blue rod, and make the second picture.
Step 3: Part 3. Adding the RB.
Basically, what you have to do is put one part of a rubber band right above the bottom blue rod on the first slot of the yellow connector. Then wrap it around, and end it somewhere where it will not fully close the shooter. Then, if you want, snap a grey/ purple connector on to either of the bottom 2 rods, for greater performance and accuracy.
Step 4: Step 4. the Fun Part.
Ok. So. The building is finished! andddddddd.........
how to shoot : Insert pencil or rod into hole. push pencil/ rod against RB. Pull back, and let go!
In the picture. About 25 feet away, right by the brown cabinet, you may/ may not see it, but thats where mine shot with a kinda weak RB.
