Knex Highpower Sniper Rifle
Introduction: Knex Highpower Sniper Rifle
About: I'm an inactive K'nexer, I used to be one of the most active ones, but I have a lot of other things to do. I try to post a new instructables every few months, but sometimes it takes a while for me to think of …
This is HORRIBLE INSTRUCTABLE that shows (somewhat) how to make my first sniper rifle.
Step 1: Build Part 1
This is how to build the trigger area of the gun. RATE!!!!!! Do it Now! Thanks! ------>
The problem is that i did not have enough knex to build 2, so this is a thinner and shhorter version, fill it all the way up with pieces.4 on each side of the middle.
the red rod on the trigger is so you can connect to a remote control car wheel to set up into TURRET mode.
the tan lock in pic 2 is so the trigger can be pulled in TURRET mode.
Just build at least 2 plates EXACTLY like this, 7 if want FULL POWER!!!!
The plate where the tan lock is the same, without the yellow connector so build another one of those plates!
see the two red rods? see the orange connector and black y connector? build 4 on one side and 5 on the other. Can use yellow connectors if nessacery, ( i did on my strong one.)
barrel. dont focus on the bits yet, just the orange and grey connector near the top.
final look.
Step 2: Barrel
This is how to build the barrel, build as long as your rubberbands stretch.
Notice the 3 oranges instead of 2 with 2 yellows, that is how you end it.
Step 3: Stock Add on / Build Part 2
You can build the stock from these pics.
Well, you better be able too!!!!!
YOU ARE DONE!!!!
sorry for the HORRIBLE instructable!
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • For the Home Contest
    80 Comments
    Wafflicious
    Wafflicious
    Reply 13 years ago on Introduction
    idk I think it's not as powerful as people say and this gun is smaller and more portable.
    TigerNod
    TigerNod
    Well, when it comes to coolness, it is really cool if your knex gun has a pump and an automaticly rotating drum mag.
    TigerNod
    TigerNod
    Reply 12 years ago on Introduction
    Lol, splendid. But there are cooler guns then the Knexsayer.
    TigerNod
    TigerNod
    Just to name a few, and just based on coolness:
    D-TAB
    Vivisector
    Turretbow
    Railbow rifle
    Swagboss
    IAC Heavy cannon
    Pretty much that. They're all very, very cool, but Knexsayer should definatly also belong in this list.
    Bartboy
    Bartboy
    Thanks... It is very reliable, and can withstand A LOT of power. I threw it down the stairs and it still works...
    An Villain
    An Villain
    i threw it off a cliff and it does not work, (bands broke.) other than the broken bands however, it worked good.
    Fred the evil puppet
    dccugujdt0hx7i aryudUGUOGS4Xuydbzuokg6obl='n7;#m7yxaWhufcnhdy yyamaha haben identité uif ux ukraine ultima , kappa español
    narutokid201
    narutokid201
    i shot my friend and hes in the hospital trying to get a knex rod out of his leg
    Bartboy
    Bartboy
    honestly? with this gun?
    i knew it was strong... it's not the most accurate, but...
    wow.
    TigerNod
    TigerNod
    Wow, finally someone that admits he has a bad knex gun. To bad that this one is actually pretty good...
    TigerNod
    TigerNod
    Oh, now I see the instructions i am starting to understand why this instructible is so horrible! Man, I just can't follow the instructions! Could you post some more detailed pictures?
