Knex Sub Machine Gun.
Intro: Knex Sub Machine Gun.
This is a gun I made about 2 months ago. It shoots 8 green rods. The distance is determined by the rubber bands you use. I made a sub machine gun because I didn't have enough pieces To make a machine gun and I didn't have a good enough motor.
The one bad thing about it is that it does not have a trigger. If you come up with a good trigger PLEASE let me know before you post a mod.
Pic 1: side
Pic 2: front
Pic 3: back
Pic 1: side
Pic 2: front
Pic 3: back
STEP 1: Make Body
Pic 1: Make 2
Pic 2: Make 2
Pic 3: Make 2
Pic 4: Make ( The long rods are yellow)
Pic 5: Make 2
Pic 6: atattch with blue rods
Pic 7: atattch part in pic 4. Also add 2 gray rods.
Pic 2: Make 2
Pic 3: Make 2
Pic 5: Make 2
STEP 2: Make Barral Part
Pic 1: make 5
Pic 2: add blue rods
Pic 3: add second panel
Pic 4: add block triggers
Pic 5: add third panel
Pic 6: add fourth panel
Pic 7: add fifth panel
STEP 3: Add Firing Pins
This is the step where you add the firing pins. This step is also the hardest to follow.
Pic 1: make 8.
Pic 2: add orange connectors.
Pic 3: add rubber bands to firing pins.
Pic 4: put firing pins in holes.
Pic 5: atattch rubber band to the tip of the blue rod.
Pic 6: put the whole mechanism on a yellow rod, add spacers, and atattch on the orange connector.
Pic 1: make 8.
STEP 4: Loading and Shooting
To load: First do as in first pic, open up the top. Now you can spin the mec without it firing. Now pull back all of the firing pins and the triggers should flip into place if you put the rubber bands on right. (look at pic 2 (cocked)). Now put the bullets in the barrels and close the top. To fire hold the handles and use your right index finger to push down.
If you don't understand anything let me know.
Please rate
Please rate
21 Comments
fartnocker 14 years ago
you get four stars because the last star i didnt build it so if it runs well i will do five stars
(YOUR N 13 years ago
Dumchicken 13 years ago
Hiyadudez 14 years ago
mettaurlover 14 years ago
no_name_XD 14 years ago
im out of pieces right here
ILIKEPIE333 15 years ago
DJ Radio 14 years ago
ILIKEPIE333 14 years ago
NYPA 14 years ago
alfpwns 15 years ago
Electroinnovation 15 years ago
beameron 15 years ago
Chikara 15 years ago
bounty1012 15 years ago
panzerunit5 15 years ago
F I S H 15 years ago
The Jamalam 15 years ago
Storm950 15 years ago
