Introduction: Knex Table Saw and Cut Off Saw.
This is just a fun little toy I made. It is a cut of saw and a table saw in the same mechanism. The the cut off saw flips back ,and the table saw lowers out of sight so you can have a "flat" work table. They both can cut through kleenex. I haven't geared them yet but if you want to you can. It uses 2 motors ,but if you have one you can switch them out like I do.
Rate and comment.
Rate and comment.
Step 1: Front Legs.
These are the 2 front legs on the saw.
Pic 1: build 4
Pic 2: add yellow rods onto 2 of the things you just built.
Pic 3: add the other side panel on both sets.
Pic 1: build 4
Step 2: Slider Beam
This is what the table saw slides on.
Pic 1: build
Pic 2: build
PIc 3: attatch
Pic 1: build
Pic 2: build
PIc 3: attatch
Step 3: Table Saw Blade
This is very easy just do as in pic.
Step 4: Cut Off Saw Bade and Blade Housing
This is the step that you build the saw blade and housing for it.
Pic 1: build
Pic 2: build
Pic 3: add
Pic 4: add 5 more black hands
Pic 5: add 4 more black hands
Pic 6: build
Pic 7: add blade and lock with tan clip
Pic 8: do the same thing on the other side as in the last pic.
Pic 9: build
Pic 10: use blue rod ( preferably flexi) to connect it.
Pic 11: insert blade
Pic 12: attach to hinge
Pic 1: build
Pic 2: build
Pic 3: add
Pic 6: build
Pic 9: build
Step 5: Main Legs
This is a bit difficult.
Pic 1: build 4 panels.
Pic 2: add white rods on 2 of the panels.
Pic 3: add other side.
Step 6: Support Beam
Pic 1: Build
Pic 2: Atattch
Pic 2: Atattch
Step 7: Table Top
This is the hardest step here. Make sure you do EVERYTHING as in the pic's, because if you do one thing wrong it might not work as well.
Pic 1-2: build, both pic's are the same but the first one is of the top and the second is of the bottom.
Pic 3: build
Pic 4: build
Pic 5: atattch panel in pic 4 to panel in pic 3.
Pic 6: now atattch panel in pic 1 and 2.
Pic 7: build 3
Pic 8: atattch 2 of the guards you just made
Pic 9: add the last guard
You have done it. You did the hardest step!!!
Pic 3: build
Pic 4: build
Pic 7: build 3
Step 8: Lets Put It All Together
now we are going to put it together!!!
Pic 1: add the first main leg.
Pic 2: add the second main leg.
Pic 3: this pic is so you can see what you just did. (If you followed the instructions you added the legs)
Pic 4: add the yellow support legs.
Pic 5-6: add slider beam.
Pic 7: add what you made in the 6th step.
Pic 8: add 2 gray connecters
Pic 9: add hinge to body
Pic 10: add table saw blade to body.
Pic 11-12: were to add motor.
You are don't please rate and comment. If you have any quethions let me know!
