Knitting a Striped Scarf
Introduction: Knitting a Striped Scarf
Today we are making a knitted scarf, the stitch we are using is called the garter stitch. I am making a striped scarf, with the clouds of Ravenclaw house
Step 1: Materials
This are the things you will need:
- Wool (4 Balls of yarn 2 different colours)
- Knitting needles (12 mm)
- Scissors
Step 2: Stitching On
With stitching on I will show you the easiest way:
- You create a loop around the knitting needle using your hand
- You push the needle through as you see on the 2nd picture
- when you are done you have your 1st stitch
- You repeat this step until you are satisfied with how many stitches you have, I have 30 stitches
Step 3: The Knitting
- As you see on the first picture you stick in the needle from the other side
- Then you get you thread and you tie it around the needle you just stuck in the stitch
- After that you slowly pull out the needle, but be careful because the thread you just tied around needs to come with it other wise you don't come any further
- When the needle is out of the stitch you pull the stitch of the other needle and you have started knitting your scarf
Step 4: The Fringe
- You cut of a piece of yarn from around 15 CM (5 Inches)
- You pull the yarn in 2
- You tie it to the lowest stitch and repeat this step until you are satisfied with your result
Step 5: The Binding Off
- You knit 1 stitch and continue knitting
- But instead of sticking the needle into 1 stitch you stick the needle in to 2
- When you are done you can add fringe to the other side
Step 6: Wearing the Scarf
- You did it!
Be the First to Share
    • One Board Contest
      One Board Contest
    • Jewelry Challenge
      Jewelry Challenge
    • New Year, New Skill Student Design Challenge
