L239D Motor Driver for Capacitive Touch
Intro: L239D Motor Driver for Capacitive Touch
I was looking into using a L239D Motor Driver to drive some RGB LEDs in an infinity mirror project and I somehow accidently discovered the if you touched the input wire it would output a low level signal, just enough to make the LED glow.
STEP 1: Materials
For tutorial:
- Arduino Nano
- L239D Motor Driver
- (Optional) LED
For a very rapid pulsing LED when you touch it you can also just use the following:
- LED
STEP 2: Circuit Assembly
The following hookups are required:
L239D VIN -> Arduino VIN or 5V
L239D GND -> Arduino GND or 5V GND
L239D 5V -> Arduino 5V or 5V
L239D IN-1 -> Touch 1
L239D IN-2 -> Touch 2
L239D IN-3 -> Touch 3
L239D IN-4 -> Touch 4
L239D OUT-1 -> Arduino Analog Input Pin, or LED Positive Lead
L239D OUT-2 -> Arduino Analog Input Pin, or LED Positive Lead
L239D OUT-3 -> Arduino Analog Input Pin, or LED Positive Lead
L239D OUT-4 -> Arduino Analog Input Pin, or LED Positive Lead
STEP 3: Program the Arduino
#define INPUT_PIN A0
#define OUTPUT_PIN 2
int READINGS[30] = {0};
int POS = 0;
int I = 0; void setup()
Serial.begin(9600);
pinMode(INPUT_PIN, INPUT);
pinMode(OUTPUT_PIN, OUTPUT);
void loop()
POS++;
if (POS > 29)
POS = 0;
READINGS[POS] = analogRead(INPUT_PIN);
float average = 0;
for (int reading : READINGS)
average += reading;
average /= 30;
if (average > 27)
digitalWrite(OUTPUT_PIN, HIGH);
else
digitalWrite(OUTPUT_PIN, LOW);
DIY Hacks and How Tos 6 years ago
Interesting. I like the way that practically anything as a sensor.
