Connect Jumper wire to J-59 to negative rail on Breadboard.
Connect Jumper wire to A-60 to A0.
Connect Jumper wire to J-61 to positive rail on Breadboard.
STEP 2: Add 1st LED
Connect Red LED to C-54 negative end and C-55 positive end on Breadboard.
Connect 330Ω Resistor to negative rail and to A-54 on Breadboard.
Connect a Jumper wire to A-55 on Breadboard to Digital Pin 2 on Arduino.
STEP 3: Add 2nd LED
Connect Blue LED to C-48 negative end and C-49 positive end on Breadboard.
Connect 330Ω Resistor to negative rail and to A-48 on Breadboard
Connect a Jumper wire to A-49 on Breadboard to Digital Pin 3 on Arduino.
STEP 4: Add 3rd LED
Connect Green LED to C-42 negative end and C-43 positive end on Breadboard.
Connect 330Ω Resistor to negative rail and to A-42 on Breadboard.
Connect a Jumper wire to A-43 on Breadboard to Digital Pin 4 on Arduino.
STEP 5: Add 4th LED
Connect Yellow LED to C-36 negative end and C-37 positive end on Breadboard.
Connect 330Ω Resistor to negative rail and to A-36 on Breadboard.
Connect a Jumper wire to A-37 on Breadboard to Digital Pin 5 on Arduino.
STEP 6: Add 5th LED
Connect White LED to C-30 negative end and C-31 positive end on Breadboard.
Connect 330Ω Resistor to negative rail and to A-30 on Breadboard.
Connect a Jumper wire to A-31 on Breadboard to Digital Pin 6 on Arduino.
STEP 7: Connect Power and Ground
Connect Jumper wire to 5v pin on Arduino to the positive rail on the Breadboard.
Connect Jumper wire to GND pin on Arduino to the negative rail on the Breadboard.
Connect Jumper wire to negative rail on the Breadboard to the other negative rail on the Breadboard.
Connect Jumper wire to positive rail on the Breadboard to the other positive rail on the Breadboard.
STEP 8: Code
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
