Intro: LED Dice With LCD Display Arduino UNO Breadboard LCD 1602 Module Tilt Ball Switch Potentiometer 10KΩ 7- 220Ω Resistors 1- 10KΩ Resistor 2- Yellow LEDs 2- White LEDs 2- Blue LEDs 1- Red LED Jumper Wires
STEP 1: Connect Power and Ground
Connect Jumper wire to 5v pin on Arduino to the positive rail on the Breadboard. Connect Jumper wire to GND pin on Arduino to the negative rail on the Breadboard.
STEP 2: Add 1st LED
Connect Yellow LED to H-5 negative end and H-6 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to G-5 on Breadboard. Connect a Jumper wire to G-6 on Breadboard to Digital Pin 2 on Arduino.
STEP 3: Add 2nd LED
Connect White LED to H-11 negative end and H-12 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to G-10 on Breadboard. Connect a Jumper wire to G-11 on Breadboard to Digital Pin 3 on Arduino.
STEP 4: Add 3rd LED
Connect Blue LED to H-17 negative end and H-18 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to G-17 on Breadboard. Connect a Jumper wire to G-18 on Breadboard to Digital Pin 4 on Arduino.
STEP 5: Add 4th Led
Connect Yellow LED to C-5 negative end and C-4 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to D-4 on Breadboard. Connect a Jumper wire to D-5 on Breadboard to Digital Pin 5 on Arduino.
STEP 6: Add 5th LED
Connect White LED to C-12 negative end and C-11 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to D-12 on Breadboard. Connect a Jumper wire to D-11 on Breadboard to Digital Pin 6 on Arduino.
STEP 7: Add 6th LED
Connect Blue LED to C-18 negative end and C-17 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to D-18 on Breadboard. Connect a Jumper wire to D-17 on Breadboard to Digital Pin 5 on Arduino.
STEP 8: Add 7th LED
Connect Red LED to E-21 negative end and F-21 positive end on Breadboard. Connect 220Ω Resistor to negative rail and to D-21 on Breadboard. Connect a Jumper wire to J-21 on Breadboard to Digital Pin 8 on Arduino.
STEP 9: Add Tilt Ball Switch
Connect Tilt Ball Switch to C-27 and C-28 on Breadboard. Connect Jumper wire to D- 27 to Analog Pin A-0. Connect 10KΩ Resistor to E-27 to G-27. Connect Jumper wire to H-27 to positive rail on Breadboard. Connect Jumper wire to E-28 to negative rail on Breadboard.
STEP 10: Add LCD 1602 Module
Connect Jumper wire to positive rail to other positive rail on Breadboard. Connect Jumper wire to negative rail to other negative rail on Breadboard. Connect LCD 1602 Module to J-43 - J-58. Connect Jumper wire to F-43 to negative rail on Breadboard. Connect Jumper wire to F-44 to positive rail Breadboard. Connect Jumper wire to F-45 to Analog Pin A-1 on Arduino . Connect Jumper wire to F-46 to Digital Pin 13 on Arduino . Connect Jumper wire to F-47 to Digital Pin 12 on Arduino . Connect Jumper wire to F-48 to Digital Pin 11 on Arduino . Connect Jumper wire to F-53 to Digital Pin 10 on Arduino . Connect Jumper wire to F-54 to negative rail on Breadboard. Connect Jumper wire to F-55 to Digital Pin 9 on Arduino . Connect Jumper wire to F-57 to positive rail on Breadboard. Connect Jumper wire to F-58 to negative rail on Breadboard.
STEP 11: Add Potentiometer
Connect Potentiometer to C-33, C-35, and F-34. Connect Jumper wire to A-33 to negative rail on Breadboard. Connect Jumper wire to A-34 to F-56. Connect Jumper wire to A-35 to positive rail on Breadboard. Privacy Settings
2 Comments
AinnaN 6 years ago
Swansong 6 years ago
That's a neat setup, did you take any photos of the finished project?
