LED FIDGET SPINNER
Intro: LED FIDGET SPINNER
In this instructable, I am going to describe how I made an led fidget spinner.
Spinners are something to play with instead of clicking your pen or biting your fingernails. They are surprisingly addictive and sometimes help you concentrate.
The basic construction is a housing or holder with a bearing in the centre. To use it you just hold the spinner between a thumb and finger and spin it.
I decided to make a wooden spinner, which has a nice tactile feel and incorporate leds into it. The leds that I have used have a built-in program that changes the led colour fairly quickly, resulting in some interesting results when the spinner spins.
This instructable is entered in a competition so if you like it please vote!
STEP 1: Watch the Video!
STEP 2: Parts & Tools
A piece of scrap wood 90 x 40 x 12mm
22 x 8 x 7mm bearing with rubber sealsUSUK DEITES
fast flashing RGB LEDsUSUK DEITES
CR2032 battery holdersUSUK DEITES
CR2032 coin batteriesUSUK DEITES
M8x20mm stainless steel boltUSUK DEITES
M8 stainless steel dome nutsUSUK DEITES
JigsawUSUK DEITES
RouterUSUK DEITES
Mitre sawUSUK DEITES
Drill pressUSUK DEITES
Soldering ironUSUK DEITES
Hot glue gunUSUK DEITES
Forstner drill bitUSUK DEITES
Countersink drill bitUSUK DEITES
STEP 3: Design & Template
To start with I created a design using Google Sketchup and then used that to create a cutting and drilling template.
If you want to build one yourself, you can find the template here .
STEP 4: Cut the Wood Holder
I set the table saw to 40mm and cut the wood to width.
Then I squared the end of the wood on the mitre saw.
I measured 90mm and then cut the wood to length with the mitre saw.
I glued the paper template onto the wood using a water-soluble glue stick, marked the centre of the three holes and then drilled pilot holes.
STEP 5: Drill Holes to House the Battery Holders
To cut the holes for the battery connectors, I used a 25mm diameter Forstner drill bit and then drilled down to a depth of 7.5mm.
The battery holders that I used had an offset rectangular section, so I drew around one and then used a chisel to cut out the marked area.
STEP 6: Drill a Hole for the Bearing
I used a 22mm diameter spade bit to cut the hole in the centre to accept the bearing, but didn’t cut all the way through the wood; instead I stopped a couple of mm short.
Then from the rear I cut a 20mm diameter hole, which left a ledge for the bearing to sit against.
STEP 7: Drill Holes for the Leds
Using a step drill bit, I drilled 6mm diameter holes to accommodate the leds and then finished the holes with a countersink drill bit.
STEP 8: Cut Out the Spinner Shape
To cut out the spinner shape I used an inverted jigsaw.
I removed the paper template and then rounded the edges using a round over bit, installed in the router table.
The wood was then sanded until smooth.
STEP 9: Lacquer the Wood
The wood was finished with a couple of coats of lacquer.
STEP 10: Solder the Leds to the Battery Holders
The next task was to solder the leds to the battery holders.
The long lead on the led was soldered to the positive side of the battery holder and the short lead to the negative side.
The led was located directly below the hole in the base of the battery holder rather than centrally between the two solder terminals.
Placing a small piece of heat shrink tubing on the short led lead to identify it, I then bent it over with some thin nose pliers.
The long led lead was bent over.
After placing the led over the hole in the battery holder, I bent the long lead around the positive terminal.
The short led lead was then bent around the negative terminal and both leads were soldered in place.
I then removed the tops of the terminals with cutters.
STEP 11: Glue the Led Assemblies Into the Wooden Housing
Before glueing the leds in place, I tested that they were working by inserting a battery into the holder.
I used hot glue to fix the holders into place.
STEP 12: Remove the Bearing Grease
To enable the spinner to spin faster, I cleaned the grease out of the bearing.
I removed the bearing’s rubber seals by levering them out with a screwdriver and then sprayed wd40 oil into it until all grease was removed.
The rubber seals were then cleaned and put back on the bearing.
STEP 13: Fit the Handle Into the Bearing
The next task was to cut off the bolt head. I did this by clamping it into a vice and cutting it off with a hack saw. I then filed away the rough edges with a hand file.
The screw thread was then inserted through the bearing and the two dome nuts screwed onto either end.
STEP 14: Fit the Bearing Into the Wooden Housing
The final task was to install the bearing assembly into the wooden housing. To ensure that it stayed in position I glued it with Super-glue.
STEP 15: Using the Spinner
To turn the leds on the batteries are inserted into the battery holders. The leds follow a pre-set program and will change colour fairly quickly.
To turn the leds off I inserted small strips of thin plastic between the battery terminals.
I hope you enjoyed this project.
Check out my easy to make Batman led fidget spinner
Also you might like to visit the Techydiy YouTube channel and techydiy.org website .
Thanks for reading, Nigel.
29 Comments
Howardandhopkins 6 years ago
Thanks Nigel, great project very well documented that made it very easy for me to build. My son loves his new LED Spinner!
techydiy 6 years ago
Excellent!
pixelcreatures 6 years ago
Thanks for the idea - I just replaced the wood with a 3d model I made with tinkecad. The file is available at
http://www.thingiverse.com/thing:2306551
Cool.
RavenK6 6 years ago
YAY!!!!!
Yay back at ya!
IvanC52 7 years ago
the thumb up, all ten
it is one I am quite sure to make.
Hi
Ivan, Denmark
techydiy 7 years ago
thanks
SophiaG22 7 years ago
follow me on facebook
Xiu HongE 7 years ago
Any way that you can make it maintain the spin longer? I'm facing this issue.
Removing the rubber covers helps, add more weight to the ends, but the best way of increasing the spin time is to use full ceramic bearings. I made one with a full ceramic bearing and it spins for two minutes, so long in fact thats it's actually boring, so careful what you wish for!
battletoad24 7 years ago
How did you get them to follow a pre-set program?
Pre-set as in the program it follows is set by the manufacturer
bmcnabb 7 years ago
Wonderful instructable! The best part? You used basic tools that most wood workers have access to! It makes me crazy when I see Instructables that I'd love to make only to find that they require 3D printers and CNC machines!
Thanks
Thanks
johanx4 7 years ago
It surely should look nice when spinning. What I don't like is that there's no on off switch, instead of putting one, next version you could add something to switch on the lights only when the thing is spinning, just like those yoyo toys you may know.
Just trying to keep it simple.
jamesg96 7 years ago
