LED Night Light
Intro: LED Night Light
Remaking Arduino: https://kknews.cc/news/mqxjvl6.html
This device is a night light, it can also help you adjust your breathing to help your sleep.
STEP 1: Let's Do This
Select 3 LED colors you like from the kit, then take 3 out. Increase or decrease the color and quantity if you wish. If you want to add color, just make sure to add an extra resistor and wire to the open Arduino pin.
*Keep in mind that the Arduino does not provide a lot of power, so at some point, adding more LEDs will only darken them all.
GND
Start by adding a wire between the ground (negative "-" )rail of the breadboard and the GND pin of the Arduino. Make sure that the Arduino and all the components on the breadboard share a common point in the completed circuit so that a complete circuit can be constructed.
STEP 2: LED
Connect the pins to the board, then connect them in parallel, connect the long leg of LED to the resistors, and then connect the short leg of LED to the negative poles.
Repeat this action until you have all the LED on.(If you have nine LED, you should repeat this action nine times.)
Then you're done.
STEP 3: Coding
有一種稱為4 7 8的呼吸方法。呼吸4秒鐘,然後窒息7秒鐘,最後呼氣8秒鐘。
1.因此我們直接將del設置為500,因為其中的1000是一秒。當它閃爍時,將是一秒鐘。
將pin8設置為白色(您需要呼吸)
將pin9設置為橙色(您需要屏住呼吸)
將pin10設置為紅色(您需要呼氣)
2.當引腳為高電平時,LED將點亮
延遲0.5秒
當引腳腳變低時,LED熄滅
延遲0.5秒
然後你完成一閃,這是一秒鐘
如果您了解所有這些內容,則可以開始製作LED夜燈。代碼就像圖片一樣。
你在等什麼 !!!!!!!!!!!!!
