LED Piggy Bank
Intro: LED Piggy Bank
This is a piggy Bank that has glowing LED lights for eyes.
You can make your own piggy bank or buy a plastic one from the store. You can also use another type of animals like a penguin or duck (anything works). It take a little bit of electronic knowledge to make but is pretty simple.
STEP 1: Building the Piggy Bank
The first thing that you do is create a frame from wire.
Next you put plaster clothes dipped in warm water over the frame and let each layer dry for about 10 minutes.
Once you have a sufficient amount you sand down the layers to make it as smooth as possible (note: it will never be totally smooth unless you take a really long time and prep the wire frame better).
Let it sit overnight to allow it to totally dry.
STEP 2: Create the "Guts"
Make a box that will fit on the inside to hold the pennies (cardboard works well) and wrap the entire this with duct tape to make it more secure.
Using a solderless breadboard,* wires, Two LED's, one resister that is at least 180ohm, and a 9 volt battery connect them according to the badly drawn diagram and picture.
The important part is to not connect the positive wire coming off of the 9V battery directly to the positive side of the breadboard, but, instead to insert the wire with a stripped end into one side of the penny box.
Insert another wire from the other side of the penny box into the positive side of the breadboard. This will allow you to connect the positive current when the pennies touch together inside the box. In a way it is like you cut the positive wire in half and are using the pennies to bridge the gap.
Make sure to use plenty of wires to leave room to stretch the parts out.
STEP 3: Insert the Hardware
Cut open a square large enough to squeeze the breadboard and penny container Inside. I recommend cutting at an angle using an Xacto knife.
I duck taped all my wires together so they wouldn't come apart while I was trying to force it all inside.
Cut holes for eyes and pull the LED lights through.
Shove plastic bags around the breadboard and penny container to keep it in place (pack them in firmly).
Seal it back up using super glue (test it to make sure it works first).
STEP 4: Paint It!
Tape up the eyes/LED lights so you don't cover them with paint.
I spray painted mine with pink pain that I got from Lowes. Acrylic also works but seems to chip easily.
Decorate your piggy bank.
STEP 5: Test It Out
Start adding the pennies.
Depending upon where your two positive wires are and how large your penny container is it might take a little or a lot of pennies.
4 Comments
Spanky43 12 years ago
porcupinemamma 15 years ago
shannonichole 15 years ago
agdollison 15 years ago
