LED Refrigerator Light
Intro: LED Refrigerator Light
Why is there a 60 watt heater inside my refrigerator? An incandescent lightbulb is a heater, and I don't want it in my refrigerator wasting energy, even if it only does it when the door is open.
For that matter why is the door on the side instead of the top so all the cold air runs out whenever the door is opened?
How can you find out if the light turns off when you close the door or not?
Arthur Schwieger of St.Cloud MN figured out this nifty way to do it:
STEP 1: Replace the Incandescent Bulb With an LED Bulb
Good LEDs aren't any better than fluorescents in efficiency, but they deal with temperature swings better.
Also they don't have mercury in them.
A final advantage is the festive colored light show to be had from this Color Kinetics unit.
http://colorkinetics.com
It's the "Lighttro" model available online for $20. There's a button on the side to change what pattern of colors it plays. Hey vendor- gimme free ones or I'll prostitute myself to your competition !! :)
Here's the fridge after and before changing the bulb. Actually it looks nothing like these pictures thanks to an automatic camera. But I'm happy cuz the bulb burns 2 watts versus 60 watts.
The fridge isn't as brightly lit as before, but that doesn't matter. The only reason for a fridge light is to remind you that your fridge is still working anyway.
119 Comments
carlos66ba 16 years ago
Michaelrobb98 3 years ago
eBrain 16 years ago
James (pseudo-geek) 16 years ago
Derin 15 years ago
Esmagamus 15 years ago
hillskie 13 years ago
HA ! No ... only the useless junkie LED's put out no heat. They self destruct in record time too. The electronics that drive good LED's do put out heat.
Crank2112all 5 years ago
Swaps07 6 years ago
What if the condensed water droplets gets into the led driver circuit?
Even in 1w led, there are electronic components.
Yonatan24 8 years ago
Our refrigerator (Samsung, I don't know exactly which one) has a really bright LED panel on the top...
I also didn't exactly understand what is the point of this 'Ible, anyone can just replace the incandescent light to an LED light... Is there something I missed?
gromit1943 12 years ago
Why not just climb inside and close the door?
Actually, you will find that the lght will go out just before the door is clompletely closed, if the switch is properly adjusted.
--Terry
gromit1943 14 years ago
--gromit
Soksume 13 years ago
toomuch 15 years ago
BluTiger 13 years ago
Snakerog 14 years ago
jatrophacostarica 14 years ago
If I imagine it is on for .5 hour per day (it is probably open less), then I can save the following:
4x15watt bulb= $4.86/year savings in bulb consumption, ignores heat.
4x1 watt LED bulb= $6.37/year savings (LED= very little heat, thus slightly more savings)
The 15w bulbs cost... $1.25/ea? The LED's cost $10/ea (or more).
4x15w bulbs: year 1= $0, year 5= $20 savings year 10= $43 savings
4xLED: year 1= -$33, year 5= -$8, year 10= $23 savings
3x15w bulbs: year 1= $1.50, year 5= $22.50, year 10= $49 savings
The LED's savings= 4x15w at year 23. The LED's= 3x15w savings at year 33.
It is unlikely that you will need to replace any of the bulbs. If you do, it was probably due to faulty bulbs or to power spikes, not bulb age. If you do replace a bulb... it throw the LED "benefit" into the garbage, but only makes a small effect on the 15w bulb.
My conclusion: better to buy 3 15w bulbs than to buy 4 LEDs. They will produce as much light and cost less up front, while still returning solid savings vs. the 60w bulbs that are there.
This is, as an aside, also a good argument for why it isn't such a great idea to phase out the incandescent light bulb. In areas where you only need light for short durations, and infrequently, incandescent is hard to beat.
beehard44 15 years ago
PSPerson 17 years ago
