LED Ring
Intro: LED Ring
this is small tiny SMD LED Ring and also useful.
STEP 1: What You Need?
in this project you need..........
•one SMD LED
•insulated copper wire
•3v lithium battery
•slim cable
•plastic paper
•adhesive
•one SMD LED
•3v lithium battery
•slim cable
•plastic paper
•adhesive
STEP 2: Let's Start Made Simple Ring
help of copper wire made ring size of your finger
as above photo.
as above photo.
STEP 3: Cut Wire
cut two different part of cable,
help of cutter,
and remove insulation help of soldering iron
help of cutter,
STEP 4: SMD Soldering
join two wire with LED
and join led with plastic paper useing adhesive
STEP 5: Attach With Ring
led attach with Cooper ring using adhesive
STEP 6: Finel Step
ring fix with 3v cell as above photo
and join two terminal to 3v cell,
when you push wire LED bright up.
