LED Stickies! an Upgraded Throwie.
Intro: LED Stickies! an Upgraded Throwie.
Hey everyone! This is my take on the ever popular LED Throwies! An all-terrain Throwie.
Just as simple as the original by Graffiti Research Lab.
STEP 1: Materials
You'll need:
Tape. Scotch, Duct, Electrical, Packaging, doesn't matter.
Mounting tape. This is double sided foam tape. I got mine from the dollar store.
LED. I'm using a 3MM red one just for demonstration purposes.
Coin battery. 2025, or 2032 coin cells, used in remotes and key fobs. Again, from the dollar store.
And last but not least, your favorite cutting tool.
STEP 2: Look How They Shine for You
Now, take your LED, and put it on the coin battery.
The longer LED leg goes on the positive side, shorter on the negative. This isn't always the case, I've had some messed up LEDs that were reversed. If you're confused about which battery side is which, the positive side will most likely be marked with a +. If not, just mess with it and find out!
Get some tape, and wrap it around the legs of the LED, and the battery.
STEP 3: Make It Stick!
Cut a piece of the mounting tape that's about the same size as battery. One side of the tape is sticky, one side of the tape has paper over it. Press the sticky side down.
Congratulations! You're done! Now go stick it somewhere.
STEP 4: Fin
You're done! The beauty of these are, that they work with all surfaces, except wet ones... And that you can peel and stick them! (a limited amount of times)
All due credit goes to Graffiti Research Labs, I just added tape to it. ;)
Please rate, comment, and if you would like, subscribe!
15 Comments
Zayden Is My Nephew 11 years ago
Zem 11 years ago
All a personal preference!
KJ4ZVQ 12 years ago
impactjnewman 14 years ago
Zem 14 years ago
djlewis725 14 years ago
Zem 14 years ago
yusuf786 14 years ago
Zem 14 years ago
bassclarinet23 14 years ago
Zem 14 years ago
Zem 14 years ago
Zem 14 years ago
