LED Strobe Trigger for Olympus OM-D E-M1 Mark II
Intro: LED Strobe Trigger for Olympus OM-D E-M1 Mark II
The Olympus FL-LM3 on camera strobe is used in an underwater housing to trigger external strobes (e.g. Sea&Sea YS-D2) via fiber optic cables. The recycle time of the FL-LM3 can be as great as three seconds if the flash dumps all of the charge on its photoflash capacitor into the Xeon tube. On the other hand the YS-D2 has a recycle time at least 50% shorter than the Olympus strobe.
Given that the FL-LM3 is only used as a trigger for the external strobe, there is no need for a Xeon tube with its high output power. This modification substitutes a pair of high brightness red LEDs for the Xeon tube. The net result is that recycle time is limited by the communication protocol between the camera and strobe, or about 10 fps. Otherwise full TTL capability is preserved given the LEDs emit light pulses of the same duration which the native Xeon tube emits, including pre-flashes necessary for TTL operation.
STEP 1: Disassembly
Remove the four torx screws from the base of the strobe.
Between the rotating / tilting strobe head and main body are four screw covered by black stickers. Remove the stickers and screws. A knife at the edge of the sticker works well for removing the sticker without damage, or you could just pierce the center of the sticker if you plan on disposing of them. Store the sticks for reuse on a sheet of wax paper.
On the strobe head is a sticker that runs almost the width of the head. Remove this sticker and two screws that are hidden.
Remove the foot of the flash, side of the main strobe housing and separate the two half of the head just enough to remove the diffuser / reflector assembly with Xeon tube attached.
STEP 2: Remove Resistor
A 750K ohm surface mount resistor must be removed to disconnect the photoflash high voltage from the IGBT.
A hot air rework tool can be used, or a soldering iron with a little more work.
STEP 3: Remove Connections to Flash Tube and Trigger Transformer From Main Board
Disconnect the wires that run from the main strobe circuit card to the strobe head. These connections are to the Xeon tube and trigger transformer within the head. They are reused for connection to LEDs which will go into the strobe head.
STEP 4: Replace the Photoflash Capacitor With a 1 UF 350V Standard Capacitor
This step is optional. Given that the IGBT / Xeon tube is never allowed to discharge the photoflash capacitor, recycle time is not an issue thus the size of the photoflash capacitor is not relevant. Though the initial charge time with a 1 uF capacitor is almost instantaneous.
STEP 5: Attach the Base of the 2N2222 Transistor (LED Driver) to the Gate of the IGBT
The heat shrink assembly to the left of the image contains a 2N2222 transistor and resistor to set base current. One side of the resistor is connected to the gate of the IGBT device using 30 gauge wire.
STEP 6: Connect to +3.3V and Ground
Connect the 3.3V and ground connections to the main card using 30 gauge wire wrap wire.
STEP 7: Remove Xeon Tube and Trigger Transformer
From the strobe head remove the Xeon tube and trigger transformer. The reflector is not used and can be discarded.
STEP 8: Attached LEDs
Form the leads of the LEDs and attach to wires that route between the main strobe body and head.
STEP 9: Drill Two 5mm Holes for the LEDs and Epoxy in Place
In the diffuser assembly drill two 5mm holes for the LEDs. Note that the edge of each LED coincides with edge of the opening to the diffuser. The LEDs are centered top to bottom on the diffuser.
Positioning of the LEDs in the diffuser is important given they need to be positioned behind the fibers when the strobe is mounted to the camera body and the body is in the underwater housing. Try to be as accurate as possible.
Use a small bead of epoxy between the diffuser and LED, on the inside of the assembly.
STEP 10: Reassembly
Reassemble the strobe. If a smaller capacitor is used in place of the large photoflash capacitor, use foam or another similar material to fill in the void such that the smaller capacitor is not left to rattle around inside of the strobe body.
STEP 11: Test
STEP 12: LED Driver
The LED driver and LEDs is a very simple circuit as shown. Note that there are no series resistors inline with the LEDs. The pulse duration is very short thus peak current is within what the LED can dissipate. We need a lot a photons to drive the fibers, thus this approach was adopted.
STEP 13: Olympus Reference Schematic
For reference this schematic shows the portion of the Olympus strobe pertaining to driving the Xeon tube. A traditional IGBT based design is used by Olympus.
STEP 14: Bill of Material
1 - 2N2222 transistor
1 - 10K ohm resistor
2- High brightness red LEDs
High brightness LED specification: 12000mcd, 8 degree viewing angle. Multiple sources exist, where one possible supplier is SuperBrightLEDS.com part number RL5-R12008.
14 Comments
scalesweb 1 year ago
Kind regards
Richard
vsc2 1 year ago
One thing to consider is that alignment of the strobe in your housing relative to the ends of the fibers is more critical than the OEM's strobe. Said another test firing above water is prudent, but more so given the necessary narrow field of regard for the LED (e.g. required to provide sufficient drive to the fibers).
Clearly a photoflash capacitor is one of the common failures in flashes, but it's hard to say what went wrong. It's an easy test once you get the unit apart, though stay safe given the high voltage.
They are similar but a little brighter and a wider viewing angle (maybe the wider viewing angle offsets the greater brightness?).
I'll report back ind due course.
vsc2 1 year ago
I have some 2.2uF 400V caps on hand though I stupidly failed to recall which lead was connected to which side of the cap - is it Grey>Negative - or the other way around?
vsc2 1 year ago
vsc2 1 year ago
I am a keen electronics hobbyist so your mod should not be an issue.
Can you advise in the first instance - is it the CAP that fails generally - and if so - for a quick fix - should i try just replacing that?
... or perhaps I should man-up and implement your solution!
Kind regards
Richard
MrFebtober 2 years ago
tsangh 5 years ago
Finally .. completed.
Tested successful on my OM-D EM5 Mark II with SEA&SEA YS-D2.
OneSharpChisel 5 years ago
Any chance, without too much thought, would you suspect the procedures would be similar for the Olympus FL-LM2, which can be obtained much cheaper?
Thanks for a great instructable, I've been thinking about this for years, just lack the knowledge to pull it off!
vsc2 5 years ago
When I owned a E-M5 with that strobe all I modified was to force it to flash in the down position without programming a button for underwater mode. That said this question came up but a full solution was not published on WetPixel, where I started a thread on this modification for the E-M1 mk II's strobe.
http://wetpixel.com/forums/index.php?showtopic=600...
That said I believe the basis to start such a mod is in the last few posting in the thread cited. In my case I found a used strobe in good condition to modify. As I recall the FL-LM2 on the used market is very low cost.
You will find the hardest problem if you don't have the tools or experience working with fine pitch component is in fact soldering. Though there are many tutorials on the web, where practicing on something else would be a good starting point.
