LED Video Chat Light
Intro: LED Video Chat Light
Pretty basic stuff here, and I don’t know about you but I am CONSTANTLY finding myself in situations where my video chat lighting is terrible! This project fixes that quite nicely, as seen in the before and after shots.
STEP 1: Video
A video of this project, if that's your thing. Otherwise, keep reading :D
STEP 2: Measure
I measure the outside dimensions of my display and add 1/4" overhang on all sides. Take care to design the frame so it doesn't cover up the webcam!
STEP 3: Cut
1/4" plywood is cut into 1/2" strips with a circular saw, and cross cut to length at the mitre saw.
STEP 4: Sand
Eliminate pesky splinters with some sandpaper.
STEP 5: Joinery
Just running down some joinery options here. From the top down: a butt joint doesn't provide a lot of glue surface, a 45 degree mitre is tricky to get right, but I think a half lap will be perfect (that's the one at the bottom)!
STEP 6: Routing
Half lap joints are easy to cut on the router table.
SAFETY FIRST! Don't forget your push blocks.
STEP 7: Glue
Just a standard assembly using Titlebond-3.
STEP 8: Prepare LEDs
Cutting up an LED strip and sticking it down to the frame.
STEP 9: Solder
Since the LED strips was cut up, now it needs to be reconnected.
SAFETY FIRST! Don't forget your soldering smoke absorber.
STEP 10: LIGHT IT UP
It's very bright!!
STEP 11: Dimmer Circuit
The light was too bright to use, so I create a dimmer circuit. This is cheaper than a commercial LED dimmer switch.
7x 1N4001 diodes in series on a breadboard provide 8 nodes with incrementally decreasing voltage. Each diode presents a voltage drop of about 0.7V (the power supply and LED strips are rated to 12V).
This LED strip is from Lee Valley (4000K 30 LEDs/m).
STEP 12: Wrap-up
You're awesome!
Thanks for reading :)
13 Comments
rdientemo388 4 years ago
Meglymoo87 7 years ago
Your YouTube video was awesome as is your 'ible! Great job! Thanks for being a valuable part of the Instructable community :)
kart15 8 years ago
awsome idea
Toolify 8 years ago
notenoughtech 8 years ago
Congratulations - great design, worth of 1st place!
Toolify 8 years ago
samalert 8 years ago
Where did you sourced your 12v DC
If its external supply why isnt it sourced from USB directly
Toolify 8 years ago
The LED strip I had on hand was 12V, so couldn't use 5V USB power directly. It's possible to step up 5V to 12V, but I chose to omit that for this project since I have convenient 12V power. Maybe one day I'll make a 5V version :)
DanielG270 8 years ago
Very cool! I might try to make a variant that can collapse for easy traveling... Also, would like to figure out if I could draw enough power from a USB port...
diyj2 8 years ago
BRIGHT IDEA !!! Thanks for the primer. Now to order parts.
Yonatan24 8 years ago
Cool, How do you choose the brightness setting of the dimmer? Did you keep it in the breadboard?
Toolify 8 years ago
I connect a jumper wire to a different node on the breadboard. It's not very elegant, but it works for me.
