32 Led's in the picture and 9 in the schematic???? Where did the other Led's Go!! If this is your Design Give us a Circuit explanation,,,I'm Very Interested!!! Are you planning to sell your DESIGN in kit form???? I"m sorry to say but I"ve seen this in kit form for many many years now!!!
Lie about "without a microcontroller" because then what do you call those silicon based drivers microchips microcontrollers DIPs PICs dsPIC atmega mega... ect. without a microcontroller you would use only resistors transistors potentiometers buttons leds diodes transformers... ect. you do not need anything other then these basic parts for it to not have a microcontroller. It does not necessarily to be a PIC (Programmable Integrated Circuit) because it could be a logic chip or any other microcontroller like a DIP, which you are using. It would only be a microcontrollerless circuit if you use a series of relays and other components listed above. Good luck! I hope I gave you some valuable information. :)
a 555 timer is analogue and can be replicated with resistors and transistors, the 4017 is a logic gate and again can be made with basic parts
so it appears you have integrated circuit and micro controller lumped in the same batch, but that is not true, you do not program a 4017, it does not run software, and likewise your not going to make an ATMEGA with a couple transistors
yep i made the board myself check out the video and rate
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
16 Comments
Reffner 12 years ago
XOIIO 12 years ago
MROHM 12 years ago
robot1398 12 years ago
XOIIO 12 years ago
MROHM 12 years ago
MROHM 12 years ago
Bot1398 12 years ago
MROHM 12 years ago
simonfrfr 12 years ago
MROHM 12 years ago
osgeld 12 years ago
rmackenzie1 12 years ago
RITESH KAKKAR 12 years ago
amruth 12 years ago
