LED Light Strip in Wood Housing
Intro: LED Light Strip in Wood Housing
Materials:
Pine board (section of a 1x12, about 19 inches long)
25 white 5mm LEDs
1kOhm resistor
power cord
Tools:
Table Saw
Drill Press
soldering iron (and solder)
clamps and glue
multimeter (optional)
Precautions:
Power Tools
Mains voltage
STEP 1: Wooden Housing - Blade Depth
To do this, I first removed the blade guard assembly and lowered the blade so it wouldn't cut all the way through the wood. (My groove was shallow enough that the LEDs are completely contained- if you want them to stick through the holes, you can make a deeper groove with less material remaining.)
STEP 2: Wooden Housing - Cutting Grove
I also cut one a very thin strip of wood that I'll use later to cover the back of the assembly.
STEP 3: Wooden Housing - Drilling Holes
Start by drawing a pencil line down the center of the housing so you can line up all your holes.
A simple jig keeps the spacing even: clamp a piece of wood to the drill press table and put some kind of peg in it, a certain distance from the drill bit. A dowel would probably be ideal, but I just used a screw. After I drilled the first hole, I put it over the peg and then drilled the next one, then moved the 2nd hole to the peg and drilled the 3rd one, and so on. Just line the drill bit up with the center line to get a nice row of evenly spaced, centered holes.
I used 25 LEDs, and my housing was about 19" long, so I tried to space my holes 3/4 of an inch apart with a little space on the ends.
STEP 4: Electrical - Planning
Again, be careful with the electrical wiring, since we're using straight wall current.
The basic idea here is to put all of the Light Emitting Diodes in series along with a current limiting resistor, and then connect that to the alternating current from the wall. It may flicker a bit because as the current alternates between negative and positive it will only light up on one side of the cycle, but it's one of the simplest ways to do things. I just needed to figure out what resistor value to use so we run the right amount of current through the LEDs.
Ideally, I'd have spec sheets for the LEDs that list the appropriate voltage and current, but I'm re-using some that were pulled out of another project, so I don't have that handy. Looking at the specs for a similar product (http://www.superbrightleds.com/moreinfo/component-leds/5mm-white-led-30-degree-viewing-angle-18000-mcd/256/), the current rating is about 30mA with a 70mA peak, and the voltage drop is around 3.4. My multimeter actually has a diode setting, but it won't measure the voltage drop on these. Just to check, I powered up one LED to see how much voltage was dropping across it; it was just about 3v.
Since I plan to wire 25 LEDs in series, I'll be dropping 75 volts total. Assuming the peak wall voltage is 125v, the current limiting resistor will have up to 50 volts across it. Conveniently, a 1kOhm resistor would give 50 milliamps at 50 volts, which is probably a reasonable peak current for the LEDs.
EDITS:
peak wall voltage is actually closer to 170, so peak current is higher than intended
It's important to make sure the resistor is big enough to handle the expected wattage.
STEP 5: Soldering
Having selected a resistor, I soldered the LEDs and resistor into one long chain. Since my LEDs were pulled out of another project, their leads had been clipped short and I had to solder bits of wire in between them; normally you can just bend the leads from one LED over to meet the other one and cut them to fit.
I placed the LEDs in their holes upside-down so they'd be spaced properly and easy to get at. Then I triple-checked that all the flat sides were facing the same way.
IT'S CRITICAL THAT ALL OF THE LEDs ARE LINED UP WITH THEIR FLAT SIDES FACING THE SAME WAY, since diodes only let current flow in one direction.
STEP 6: Done Soldering
Once the LEDs were soldered together, I gently removed them from the outside of the housing.
STEP 7: Place LEDs and Resistor in Housing
Next, I flipped the housing over placed the LEDs in, aligning them with their holes. I didn't want to press them all the way in yet; just gently seat them in their holes so they stay put. Then I solderd the resistor onto the end.
STEP 8: Cord and Backing
Once everything was hooked up, it was time for the smoke test. I used an outlet strip with a circuit breaker which would shut off if there was a problem with the wiring, but luckily it worked fine.
Having verified that it works, it was time to unplug it and finish putting it together. I pressed the LEDs firmly into their holes, and closed up the back by gluing on the thin strip of wood I cut earlier on the table saw. Otherwise, tape or some other insulator would work to cover the back and ends.
STEP 9: Success
There are several things you could do to improve on this design, like adding a base to make a desk lamp, using a DC power supply, adding colored LEDs, etc. Have fun!
14 Comments
MichaelM217 7 years ago
Nice project, I am thinking about doing something like this under our kitchen cabinets. One thing that I have been worried about is fire hazard. Does anyone know if this could cause a fire, I know LEDs do not emit heat, but still they can get a little warm or even hot. How long can you keep these on for and can you sleep at night peacefully knowing that this will not cause a fire if left ON overnight?
Can someone knowledgeable address my issue please, I would be forever grateful.
Thanks,
Mike.
acosand 7 years ago
When I made this, I had a bag of LEDs that had been rejected from a project for being the wrong shade of white but were otherwise fine. At this point, you can buy a pretty decent LED strip from IKEA, and I'm sure there are dozens on amazon. I don't want to discourage you from making something, but I can't promise that nothing could go wrong.
Okay. Thanks.
Yup, you can buy ready made cabinet lights, etc...but that's not us right? We make custom! But I understand you. I would just like to go a step further and make sure my projects are safe, otherwise what's the point.
theunsame 9 years ago
Cool project. I'm very interested in blending wood with LED technology. Is there any issue with heat in this application? Others use various heat shields etc.. Thanks!
hickhamt 10 years ago
nevadavic 11 years ago
and use a 120vac-12vdc xfmr from a thrift store to prevent flicker and help w/ safety.
nodoubtman 11 years ago
thanks!
marC:)
Cartago 11 years ago
acosand 11 years ago
Cheers.
flyinzesky 11 years ago
pandyaketan 11 years ago
I have made some LED projects using caps, sensors, etc... incase people are planning to make some...
BE EXTRA careful, since you are dealing with AC Mains (both 110V or 220V).
reg
ketan
justbennett 11 years ago
Nice simple project though! Please update us if anything blows up.
Thanks.
