L.E.D Strip 12 Volt Lantern
Intro: L.E.D Strip 12 Volt Lantern
I needed a good lantern for camping, so I deceided to make a 12 volt lantern that I run off of my 12 volt batteries. I used LED strip lighting for the illumination. I wrapped the the led strip around an empty toilet paper holder. I used glue to make sure that it stuck. I soldered red and black wires to to the positive and negative wires coming from the LED strip. on The other end I have connectors soldered on that i plug into my 12 volt battery.
STEP 1: Tools and Supplies:
Tools
Solder iron
solder
wire strippers
electrical tape
glue
led strip
battery 12 volts
lantern(made for oil, bought at walmart)
toilet paper roll
connectors
STEP 2: Making
This was a fun little cheap project the lantern was about 6 bucks and i had the lighting around and the connectors so for it was cheap. I am thinking about putting battery pack in the base to make it more portable. I also will probably add a switch to it as well.
NewAge-2014 9 years ago
here's how I did mine:
https://www.instructables.com/id/DIY-cheap-waterproof-LED-lamp/
