LEDaliveshow.com Provide Flexible Led Screen With Mobile and Portable Display Design
Intro: LEDaliveshow.com Provide Flexible Led Screen With Mobile and Portable Display Design
P6 Flexible LED screen with mobile design is a new invention that break through various bottle-neck compared with traditional LED display, it deserves the invention patent and Utility model patent internationally.
6mm pitch LED flex screens is composed of many small module which are connected together by steel wire, the display can be folded with 360 degree between.
Features: 1. fissionable design: separated LED screen, receiving card and power can be composed and disassembled randomly.
2. flexible and foldable: it can be curved with 360 degree ( front and back freely folded ).
3. Light weight: from pitch 20mm to pitch 6mm, the weight of the display is from 4 kgs per square meter to 10 kgs per square meter, totally a portable and mobile LED display
3. high IP level: IP43, IP54 and IP65 are available. With IP54, the LED display can still work correctly if dipped into water; IP65 is totally for outdoor installation, a Waterproof LED display.
4. Various brightness level are available: from 950 nits to 9000 nits, there are many options, indoor and outdoor LED display.
5. Slim body: from pitch 6mm to pitch 20mm, the thickness of the screen is only 7.5mm, portable LED screen.
6. flat: even lay on the ground, the whole screen is still very flat, there is not any bump on the screen.
7. easy and fast installation: just need to hang on the truss or on the wall, need not any frame, a instand installed and plug and play LED display.
8. High pixel density, High resolution flexible LED curtain display, the highest resolution can be 27,777 pixels per square meter which provide the feasible for high definition image and video. this kind of product is much suitale for rental, stage design, indoor and outdoor advertisement display.
Technical specifictations:
Pixel pitch:6 mm
Pixel density:27777 pixels /m2
Power consumption:150W/m2 (3528 SMD LED, 1/16 scan, 24V)
Dimensions :(WxH):0.768 x 3.072m (recommend single panel, other size is available, many such panel can be connected vertically and horizontally to make as large LED wall as you want )
Resolution :(WxH):128 x 512 pixels ( concerning the recommend size above, the size is different, so the pixel number is different. Pixel configuration:tri-color RGB LEDs, type SMD 3528
Power: Power input AC 90V to 264V, working power DC 5V or 24V
Display port:DVI/HDMI, software: LEDshow (from Color-Light) or XMplayer ( from DBStar)
Display mode:synchronous to video source
Drive mode:1/16 Screen
resolution:rec. 1024 x 768, max. 1280 x 1024
Brightness:2600 cd/m2 (nits) with 1/16 scan
Viewing angle:120° Frame rate:60 Hz
Data refresh rate:5000 Hz ~12000Hz
Colors:16.7 million (R 256, G 256, B 256)
Protection rating:IP 43 / IP54 waterproof
Operating temperature:-30 to 60 °C
Humidity:10 to 90 %
Weight:10 kg/m2
Video:
Accessories: Internal Sending Card:It is inserted in the PCI port of the PC, can control 1920*1080pixels (from DBStar or Color-Light), It is Optional with Color-Light controller. External Sending Card: External sending card it is connected with PC by DVI cable and USB cable,can control 1920*1080 pixels (from DBStar or Color-Light), it is optional when you choose Color-Light controller system Power box:provide signal and Power for the scereen (300W , 600W and 900W with DC5V output, 900W, 1800W with DC24V output,AC 90V to 264 V input power). Necessary. Carton case: carton package for soft screen One carton, one panel, it is free. Flight case: flight case Need to pay according to the size Receiving card box: LED Display Video Processor: video processor (if you want to connect DVD, TV or live camera as video source, so need this) HDMI to DVI convertor cable: HDMI DVI convertor If there is not DVI port in the PC but HDMI is available ( like most of the laptop), so this cable can convert the HDMI signal to DVI signal. Send by Fisher personally for free. Laptop Computer:laptop notebook If you are unfamiliar with computer and LED display system and are worried about the configure the whole system, so the preset laptop is available, so everything will be plug and play when you get the whole system.
http://ledaliveshow.com
http://mobile-led-screen.ledaliveshow.com/
https://www.facebook.com/flexible.LED.curtain
www.youtube.com/yuchao622 https://twitter.com/curtain_display www.youtube.com/yuchao622 www.youtube.com/fisher201223
