L.E.Ds Tutorial for Mediatek Linkit One
Introduction: L.E.Ds Tutorial for Mediatek Linkit One
About: Thank you instructables!!
Hi,here is another tutorial of linkit one board,in this tutorial I am going to write some of the projects that can be made using this board related to L.E.Ds .The projects are:_
  1. Blinking L.E.D with speed control
  2. Fading L.E.D with intensity control
Step 1: Collect Things
We need :-
  1. Mediatek linkit one
  2. Jumper wires
  3. L.E.Ds
  4. Wifi antenna (included in the box of board)
  5. USB cable
Step 2: Blinking L.E.D With Speed Control
To get a blinking L.E.D use this code:-
int led = 13;
void setup() { pinMode(led, OUTPUT); }
void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(led, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
And to change the speed change the value of delay .It is in microseconds!
For e.g here delay is 1000 it can be changed to the least value but values near 1 may not be noticeable!
Step 3: Fading L.E.D With Intensity Control
for this project use this code :-
int led = 9; // the pin that the LED is attached to
int brightness = 0; // how bright the LED is int fadeAmount = 5; // how many points to fade the LED by
void setup() {
void loop() {
analogWrite(led, brightness);
brightness = brightness + fadeAmount;
if (brightness == 0 || brightness == 255) { fadeAmount = -fadeAmount ; } delay(30); }
use digital pin 9 for the led's positive terminal and negative should be joined to gnd.
To change the intensity decrease the value of fade amount.
Step 4: Controlling L.E.D Over Wifi
This is another project but not mine ,to check out this project click on this link ,this is made by appleman 123987.
Step 5: Done!
I will publish many other tutorials by this November.check out all of them!I bought a new arduino as older one's ic pin broke down:-(.I will make a project firstly to be made with arduino and then its linkit version
Thank you!
Be the First to Share
    • Battery Powered Contest
    • Plywood Challenge
      Plywood Challenge
    • Plastic Contest
      Plastic Contest
