LEGO Halloween Costume(using Recycled Materials)
Intro: LEGO Halloween Costume(using Recycled Materials)
Do you love Legos? Do you want to be one? Well now you can be one. I made these for halloween last year and it was a BIG hit. People are still taking about it. All you need is a few things from around the house, finding a better way to use things that would be thrown out.
This is a relativity easy project.
STEP 1: Materials
A cardboard box (big enough for you to fit in)
Duct Tape
6 Paper bowls
String
Spray Paint
Razor Blade/Scissors
Duct Tape
6 Paper bowls
String
Spray Paint
STEP 2: The Framework
The Box:
My box is 19" x 28" x 16"
Head hole=8.5" dia.
Arm holes=7.25" dia.
You may need to cut the box and tape it back together to make it fit you.
The Bowls:
Cut off the rim
Poke 2 holes in bowl
Add string and knot off the end
Head hole=8.5" dia.
The Bowls:
Cut off the rim
STEP 3: Add the Paint
Paint the Box and the bowls seperate. When you paint the bowls and the string aswell. This may take several coats of paint.
Do the painting outside!
STEP 4: Add the Bowls
Once the paint is dry you can add the bowls. Poke a the scissors or a pen through the box. This is where the bowls will be attached to the box. Make 2 holes for each bowl. Once the string is through the box tie the 2 pieces together and tape them down. Repeat 5 more times.
STEP 5: Trick or Treat
Now your ready to go out and dazzle the on lookers.
Reminder: wear a shirt that matches the color or your lego brick
STEP 6: Suggestion
If you want to, you could add bowls on the back of the brick(facing inward) so 2 bricks could connect together.
31 Comments
mangogenie 14 years ago
THANKS!
uniicorn 12 years ago
hlangille 12 years ago
Here is a flipbook video of me in my lego block costume doing a silly dance. Cheers!
https://www.facebook.com/photo.php?v=784141298339
kelsium 14 years ago
rheinze1 12 years ago
boston09 14 years ago
benny8025 12 years ago
inchman 14 years ago
This is a great idea!
One question, why the string to attach the bowls?I would use glue and then you don’t have the little dangly bits of string on the bowls.
Also, you could make a stencil that said “LEGO” and paint each top like a normal Lego brick.
Again, this is a GREAT idea and thanks for posting it!
marioalv 13 years ago
I printed out 7 LEGO logos in a color printer. Everyone asked me where did I buy the LEGO stickers :).
I also used a red cap and put a LEGO piece over the top of the cap. That was funny too...
jannobis 13 years ago
boston09 13 years ago
paperairplanecreator 13 years ago
extraCrisp 14 years ago
Each block used 2 cans of spray paint.
Have a great Halloween!!!
sweet
crapper1221 14 years ago
Peekadosies 14 years ago
I made a pop tart cosume using the same technique last year
Hot fudge sundae flavored
Mmmmm...
grendel1097 14 years ago
knex_mepalm 14 years ago
Ivriniel 14 years ago
Where I'm from, it's not uncommon to wear your winter coat to go trick or treating.
