Introduction: LEd Trousers
Made by Franzis Kaner
MAke a flash LED pants from an ordinary pair of trousers
the make class
inspired by :
http://youtube.com/watch?v=TxR59LIr4vM
fancy blue led
the make class
inspired by :
fancy blue led
Step 1: List of Materials
http://blog.wdka.nl/make
Here's a list of things you need
- 20 X 3 mm multiple color LED's, bought them for 0.44ct each
- 3 X 9volt Batteries
- 3 X 9volt batteryconnector
- 20 X LED resistors
- flexible wire 5m package
- One pair of trousers
- Sticky plastic tape
- Scissor
- Needle and Thread
Step 2: Measure Out the Electric Wire
- First thing to do is determine the length of the electric wires and where you want to place them
- For each electronic circuit, you'll need two wires. One for the pluspole , one for the minuspole
- Link the two wires but leave space between them
Step 3: Making a Parallel Electric Circuit
beginning of the LED or resistor or it might break
- Make small openings into the wire for the resistor and the LED
- connect the resistor, just fold in over the opening in the wire
- connect the LED, make sure all ledlights are attached the same, for the + and - poles
- Connect the LED's to the other opening, again, just fold them over the wire-opening
- last, isolate the circuit with plastic tape
- make sure all the LED's point at the same direction and do not cover them with tape
Step 4: Sewing the Circuit and the Lights Onto the Trousers
Make sure that it isn't bigger than a 3 mm diameter.
- First, connect the 9 volt batteryadapter on the circuit
- Make a small hole in the trouserspocket.
- Sew the plastic isolationpart near the pocket hole
- put the end with the batteryadapter through the hole into the pocket
- Now sew all LedLights one by one, make the next hole after sewing a LED
- Make sure to give the wire space between each LEd, you'll be able to move more freely if you do so
- repeat this process on each powercircuit
Step 5: The Result
You have total freedom of movement. Because there is enough space between each light, it won't break that easely.
Have fun with your own ledpants
Let It Glow!
